* Makefile.am: Merge in include/Makefile.am.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* TOOL_TARGETS: Updated.
* PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed
since they were obsolete.
* src/mount.c: Per PR297, correct fs_mountme failure
paths.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* directory.cfg: Ditto.
* lib.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* Makefile.am: Add Templates/*.
* Templates/Makefile.am: Remove.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
Further preparations for autoconf > 2.52:
* aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else.
* aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg.
* aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* src/psignal.c: Fix counting problem which resulted in too many
entries being in the POSIX signals default behavior table.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* acinclude.m4: Adapations to autoconf > 2.52.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* src/_servtgt.c: Removed warning by adding support for ITRON
tasks and rolling multiple loops into 1.
* src/m68k/rdbg_f.c: Removed warning.
* console/console.c, network/network.c: Removed warnings.
* irq/irq.c: Removed warnings.
* network/network.c: Removed warnings.
* src/rpc/pmap_rmt.c: Removed warnings.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* console/i8042.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* clock/clock.c: Removed warnings.
* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, network/ne2000.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress
warning.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* console/console.c, start/start.c: Removed warnings.
* Makefile.am: Use mkinstalldirs instead of mkdir.
* console/console.c, start/start.c, startup/efi68k_wd.c:
* startup/m68k-stub.c: Removed typos.
* sh7045/score/ispsh7045.c: Fixed typos.
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and
removed warnings.
* sh7045/score/cpu_asm.c: Fixed typo.
* ChangeLog: Corrected.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
* idtcpu.h: Removed warnings.
* cpu.c: Removed warnings.
