* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Ditto.
* include/rdbg/i386/Makefile.am: Ditto.
* include/rdbg/m68k/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto:
* src/Makefile.am: Ditto.
* src/i386/Makefile.am: Ditto.
* src/i386/any/Makefile.am: Ditto.
* src/m68k/Makefile.am: Ditto.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
* ide/Makefile.am: Use dirstamps for preinstallation. Reformat.
* network/Makefile.am: Ditto.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* wrapup/Makefile.am: Reflect $(dirstamp) changes.
* Makefile.am: Add $(dirstamp) to compilation rules.
Fix misc. typos.
Add AM_CPPFLAGS += -I$(top_builddir).
* Makefile.am: Fix libc_OBJS.
Remove MACROS.
Restore libc/$(ARCH)/lib.a.
* Makefile.am: Preinstall adainclude_HEADERS.
Remove MACROS.
* configure.ac: Reflect having removed
libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am.
* libc/Makefile.am: Remove.
* lib/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* configure.ac: Reflect changes to libmisc/*.
* capture/Makefile.am: Remove.
* cpuuse/Makefile.am: Remove.
* devnull/Makefile.am: Remove.
* dummy/Makefile.am: Remove.
* dumpbuf/Makefile.am: Remove.
* fsmount/Makefile.am: Remove.
* monitor/Makefile.am: Remove.
* mw-fb/Makefile.am: Remove.
* rtmonuse/Makefile.am: Remove.
* serdbg/Makefile.am: Remove.
* shell/Makefile.am: Remove.
* stackchk/Makefile.am: Remove.
* untar/Makefile.am: Remove.
* wrapup/Makefile.am: Merge-in former libmisc/wrapup/Makefile.am
* wrapup/Makefile.am: Remove.
* wrapup/.cvsignore: Remove.
* configure.ac: Remove libmisc/wrapup/Makefile.
* configure.ac: Reflect changes to libfs Makefile.ams.
* Makefile.am: Merge-in src/Makefile.am, src/imfs/Makefile.am,
src/dosfs/Makefile.am.
* src/Makefile.am, src/imfs/Makefile.am, src/dosfs/Makefile.am:
Removed.
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am:
Removed.
* Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am,
src/Makefile.am.
Various fixes. Reformat.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
PR 524/filesystem
* src/newlibc.c: Address 1K buffer leak from incomplete cleanup of
newlib reentrancy handler.
PR 523/filesystem
* src/malloc.c: Make malloc family safer for use from ISRs and
dispatching critical sections. If in a critical section while doing
a free(), then the free is deferred until the next malloc() attempt.
* MAINTAINERS: New file.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* project.am: Remove $(PROJECT).info* from CLEANFILES (Doesn't work
with automake-1.7f/1.8 anymore).
* aclocal/canonicalize-tools.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rtems-debug.m4,
aclocal/check-tool.m4, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4,
aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/multi.m4,
aclocal/multilib.m4, aclocal/prog-cc.m4,
aclocal/rtems-top.m4, aclocal/sysv-ipc.m4:
Fix underquoting to silence automake-1.8.
* aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4,
aclocal/check-custom-bsp.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-posix.m4,
aclocal/check-tool.m4, aclocal/config-subdirs.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4,
aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4,
aclocal/multilib.m4, aclocal/path-ksh.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4,
aclocal/project-root.m4, aclocal/rtems-test-no-pause.m4,
aclocal/rtems-top.m4, aclocal/target.m4,
aclocal/tool-paths.m4:
* aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4,
aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4,
aclocal/i386-gas-code16.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/prog-cc.m4,
aclocal/prog-cxx.m4, aclocal/project-root.m4,
* acinclude.m4: Fix underquoting to silence automake-1.8.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
PR 519/filesystem
* include/rtems/libio_.h, src/eval.c, src/rmdir.c, src/unlink.c: Check
write permissions in parent directory for file or directory delete
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
