* | updated to correct problem in decoding arguments provided to configure. | Joel Sherrill | 1997-05-22 | 2 | -10/+42 |
* | patch from Eric Norum | Joel Sherrill | 1997-05-21 | 1 | -4/+4 |
* | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1997-04-25 | 2 | -0/+6 |
| | | | | directive. | ||||
* | Added to comment header block to include new status directive. | Joel Sherrill | 1997-04-25 | 3 | -0/+3 |
* | Updated to point to README.configure for build instructions. | Joel Sherrill | 1997-04-25 | 3 | -9/+9 |
* | updated to reflect new license per John Gwynne's permission. | Joel Sherrill | 1997-04-25 | 4 | -52/+12 |
* | Updated to reflect changes since 3.6.0 | Joel Sherrill | 1997-04-23 | 1 | -17/+2 |
* | incorrect screen name for multiprocessing tests. | Joel Sherrill | 1997-04-22 | 1 | -1/+1 |
* | Patch from Chris John <cjohns@awa.com.au> to add use of a select statement | Joel Sherrill | 1997-04-22 | 7 | -5/+318 |
| | | | | | | in the unix port idle thread task. This should keep the entire application from blocking when any component does a blocking application. Also added TOD_MICROSECONDS_TO_TICKS. | ||||
* | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1997-04-22 | 3 | -0/+6 |
* | multiprocessing fixed on linux by fixing cpu.c so correct form of | Joel Sherrill | 1997-04-22 | 2 | -6/+8 |
| | | | | semctl was being invoked. | ||||
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 18 | -210/+68 |
* | File changed to reflect change in license and copyright. | Joel Sherrill | 1997-04-22 | 2 | -10/+10 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 2159 | -10724/+10724 |
* | LICENSE file is now only in top directory. | Joel Sherrill | 1997-04-22 | 1 | -9/+1 |
| | | | | README updated. | ||||
* | incorporated feedback from Mark. | Joel Sherrill | 1997-04-22 | 2 | -11/+18 |
* | changed license to modified GPL | Joel Sherrill | 1997-04-22 | 2 | -113/+361 |
* | corrected some email addresses | Joel Sherrill | 1997-04-22 | 1 | -4/+4 |
* | corrected Tony Bennett's email address | Joel Sherrill | 1997-04-22 | 1 | -1/+1 |
* | Added support for HW API package | Joel Sherrill | 1997-04-22 | 2 | -11/+7 |
* | Added support for Hardware API. This will be distributed as a separate | Joel Sherrill | 1997-04-22 | 2 | -8/+105 |
| | | | | component which can be loaded on top of the RTEMS source tree. | ||||
* | Corrected spelling of --enable-gcc28 argument | Joel Sherrill | 1997-04-18 | 2 | -4/+5 |
* | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 1997-04-18 | 6 | -12/+12 |
* | Changed format of comment blocks to C comments. | Joel Sherrill | 1997-04-18 | 3 | -51/+51 |
* | Duplicated timerisr symbol as _timerisr to avoid tool naming problems. | Joel Sherrill | 1997-04-18 | 1 | -0/+6 |
* | Updated to reflect --enable-gcc28 and --enable-libcdir options. | Joel Sherrill | 1997-04-18 | 1 | -13/+22 |
* | Corrected incorrect settings for locations of psx and sp test screens. | Joel Sherrill | 1997-04-18 | 1 | -2/+2 |
* | Modifications to add --enable-libcdir and --enable-gcc28. These | Joel Sherrill | 1997-04-18 | 3 | -6/+50 |
| | | | | | trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released. | ||||
* | Added gen68360_040. | Joel Sherrill | 1997-04-17 | 2 | -2/+2 |
* | Fixed path which points to shared directory for all BSPs. | Joel Sherrill | 1997-04-16 | 20 | -20/+20 |
* | fixed spacing | Joel Sherrill | 1997-04-16 | 1 | -1/+3 |
* | added fpsp support. | Joel Sherrill | 1997-04-16 | 1 | -0/+2 |
* | Update from Eric Norum. | Joel Sherrill | 1997-04-16 | 8 | -174/+414 |
* | Updated to reflect Tony Bennett's new email address and the incorporation | Joel Sherrill | 1997-04-16 | 1 | -3/+5 |
| | | | | of the ka9q stack, m68040 fpsp, gen68360_040 bsp submitted by Eric Norum. | ||||
* | Added FPSP support for MC68040 | Joel Sherrill | 1997-04-16 | 4 | -7/+90 |
* | Added CVS Id's | Joel Sherrill | 1997-04-16 | 2 | -0/+7 |
* | Added the MC68040 Floating Point Support Package. This was ported | Joel Sherrill | 1997-04-16 | 47 | -0/+16820 |
| | | | | | to RTEMS by Eric Norum. It is freely distributable and was acquired from the Motorola WWW site. More info is in the FPSP README. | ||||
* | Added --disable-tcpip option. | Joel Sherrill | 1997-04-16 | 1 | -5/+45 |
| | | | | Add discussion of the pecularities of the i386-go32-rtems configuration. | ||||
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 6 | -12/+30 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | Added directories to place test output screens into as part of fixing | Joel Sherrill | 1997-04-15 | 1 | -3/+4 |
| | | | | difftest. | ||||
* | Added line to install test screens so difftest does not have to have | Joel Sherrill | 1997-04-15 | 65 | -7/+137 |
| | | | | | | a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | ||||
* | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 1997-04-15 | 20 | -19/+51 |
| | | | | returned an error to using a single shared copy of this file. | ||||
* | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 1997-04-15 | 10 | -9/+48 |
| | | | | implementation as all m68k BSPs. | ||||
* | replaced linking of source from mvme147 drivers with use of vpath to | Joel Sherrill | 1997-04-11 | 4 | -29/+8 |
| | | | | simply search into that directory and get the necessary files. | ||||
* | removed commented out line performing a link | Joel Sherrill | 1997-04-11 | 2 | -2/+0 |
* | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 1997-04-09 | 8 | -10/+18 |
| | | | | tasks table. | ||||
* | new test | Joel Sherrill | 1997-04-09 | 26 | -0/+1604 |
* | added cpuuse and rtmonuse | Joel Sherrill | 1997-04-09 | 1 | -1/+1 |
* | printing task names now instead of id numbers | Joel Sherrill | 1997-04-09 | 3 | -9/+48 |
* | new files. | Joel Sherrill | 1997-04-09 | 21 | -0/+1649 |
