The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Update #4180
Add _Per_CPU_Is_ISR_in_progress() as an optimized version of
_ISR_Is_in_progress().
Update #4406.
rtems_task_restart() may be called from within interrupt context. So
checking only that the thread to restart is equal to the executing
thread is insufficient to determine a self restart. We have to also
check that no ISR is in progress. Merge _Thread_Restart_other() and
_Thread_Restart_self() into one _Thread_Restart() since they share a lot
of common code.
Close #4412.
Unconditionally set the real priority of the task to its initial
priority during a task restart.
Close #4411.
This simplifies rtems_task_restart().
Close #4410.
Add a library for support functions used by validation tests. Rename
tc-support.* to tx-support.* since this file does not contain test
cases.
Replace defines with an enum.
Update #4406.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This avoids an integer division at runtime.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid
unreachable code in _CORE_message_queue_Close() in case only
user-provided message buffers are used.
Update #4007.
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
Document changed error status.
Update #4401.
Document new error status.
In the action requirements, some pre-conditions are not applicable
depending on the state of other pre-conditions. There is no particular
order in the pre-conditions, so we have to check the N/A status
individually.
Make sure all conditions to do a proper memory allocation are satisfied
before a zero size memory allocation is performed.
Update #4390.
This patch adds asserts to fix coverity defects
1) CID 1474437 (Out-of-bounds access)
2) CID 1474436 (Out-of-bounds access)
From manual inspection, out of bounds access cannot occur due to
bounds checking but coverity fails to detect the checks.
We are adding asserts as a secondary check.
In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
Move all error checks into posix_memalign() so that the returned memory
pointer is set to NULL under all error conditions except
memptr == NULL.
Use parameter names of POSIX documentation.
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Check for a NULL processor set pointer.
Added conditionals to ensure that long double function tests were only
built when newlib has long double math functions.
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with uintptr_t,
which will work for both 32 and 64 bit architectures.
These two functions are no longer used outside of _Once().
The allocator mutex is recursive and already used for the task creation
in rtems_timer_initiate_server(). Just use this mutex instead of the
once mutex to serialize the initialization. This avoids a dependency on
condition variables which are not used here.
The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
Update #3866.
Flexible array members must not appear in the middle of a structure.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
Close #3866.
Update #3866.
Update #3866.
This may reduce the code size a bit.
Replace copy and paste with a proper description.
If only one constraint is present, then use a single sentence, otherwise
use a list for the constraints. Format the constraints so that the line
length limit is maintained.
CID 1399709: Dereference after null check in
rtems_trace_buffering_shell_save().
Closes #4329
CID 26033: Dereference after null check in _Objects_Extend_information().
Closes #4326
The 'sc' variable was originally storing the return value of mkdir().
This was causing an issue, so it was changed to make it to where we
ignored the return value with (void). The 'sc' variable was left in
by mistake.
