* | Removed all references to HOST_ARCH including the file gcc.cfg.in. All | Joel Sherrill | 1999-10-26 | 10 | -474/+4 |
| | | | | | host programs are now compiled with automake generated rules. This was done after discussions with Ralf Corsepius and Eric Norum. | ||||
* | idir=/opt/tmp/opt/rtems | Joel Sherrill | 1999-10-26 | 7 | -26/+13 |
| | | | | | | | | | | | | rdir=/opt/rtems cd $idir find . -type f | while read file do if [ ! -f ${file} ] ; then echo ${file} missing fi done | ||||
* | cat /tmp/j | while read f | Joel Sherrill | 1999-10-26 | 54 | -7836/+0 |
| | | | | | | do rpm -qi $f 2>&1 | grep -v "is not ins" done | ||||
* | Removing automatically generated files. | Joel Sherrill | 1999-10-26 | 4 | -1088/+0 |
* | Removed generated file. | Joel Sherrill | 1999-10-26 | 1 | -1101/+0 |
* | New versions for gcc and patch. | Joel Sherrill | 1999-10-26 | 1 | -2/+2 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move | Joel Sherrill | 1999-10-26 | 8 | -12/+11 |
| | | | | c/src/lib/libmisc to c/src/libmisc. | ||||
* | cat /tmp/j | while read f | Joel Sherrill | 1999-10-26 | 42 | -5982/+0 |
* | Patch rtems-rc-19991011-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-10-26 | 2 | -6/+5 |
| | | | | fixes a minor configuration bug. | ||||
* | Regenerated | Joel Sherrill | 1999-10-26 | 6 | -27/+34 |
* | New ideas on test incorporated. | Joel Sherrill | 1999-10-26 | 1 | -9/+17 |
* | Modifications from Erik Ivanenko <erik.ivanenko@utoronto.ca> to add | Joel Sherrill | 1999-10-26 | 2 | -5/+17 |
| | | | | | proper Multiboot signature to pc386 BSP. This enables Grub to recognize the image. | ||||
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> to fix some | Joel Sherrill | 1999-10-26 | 1 | -28/+68 |
| | | | | reported bugs in the start code. | ||||
* | Fixed line too long problems. | Joel Sherrill | 1999-10-25 | 3 | -14/+22 |
* | Updated copyright year and corrected image path. | Joel Sherrill | 1999-10-25 | 1 | -4/+4 |
* | Updated copyright year. | Joel Sherrill | 1999-10-25 | 2 | -2/+3 |
* | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 1999-10-25 | 10 | -74/+143 |
| | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | ||||
* | Regnenerated following update from Ralf. | Joel Sherrill | 1999-10-25 | 6 | -27/+34 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 5 | -33/+56 |
* | Added descriptions of the mount table entry elements. | Jennifer Averett | 1999-10-25 | 1 | -0/+97 |
* | Modified url references to be dynamic links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Added definition of DDD. Modified url references to be | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
| | | | | dynamic links. | ||||
* | + Filled in information on IMFS_freenod and IMFS_freenodinfo | Jennifer Averett | 1999-10-25 | 1 | -13/+58 |
| | | | | + Filled in information on the imfs_fsunmount and imfs_unmount methods. | ||||
* | + Cleaned up lines that were too long. | Jennifer Averett | 1999-10-25 | 1 | -129/+19 |
| | | | | | + Removed subheading File - This is not valid for the callback descriptions. + Filled in information on freenod | ||||
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 9 | -50/+54 |
* | Added information on how the directory is stored for future referance | Jennifer Averett | 1999-10-25 | 1 | -2/+3 |
| | | | | during a mount. | ||||
* | Formatting improvements. | Joel Sherrill | 1999-10-25 | 3 | -12/+80 |
* | Enabled Ada95 interrupt support chapter and reformatted a | Joel Sherrill | 1999-10-25 | 6 | -35/+48 |
| | | | | bunch of stuff to avoid line wrappings. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> to address the following problem | Joel Sherrill | 1999-10-25 | 3 | -3/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 2 | -0/+16 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Added notes for new test. | Joel Sherrill | 1999-10-25 | 1 | -0/+19 |
* | Made html links browsable. | Charles Phillips | 1999-10-25 | 1 | -4/+3 |
* | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 3 | -73/+73 |
| | | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | ||||
* | Made urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
* | Made html urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Made html urls browable links. Updated the reference to the | Charles Phillips | 1999-10-25 | 1 | -6/+48 |
| | | | | | U.S. Army Missile Command to show the merger with the Aviation Command | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 4 | -28/+32 |
| | | | | <raguet@crf.canon.fr> to use a local variable. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 6 | -216/+222 |
| | | | | process. | ||||
* | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 1999-10-25 | 10 | -122/+82 |
* | Changed to use interrupt driven console. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 14 | -2/+582 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 8 | -2184/+2184 |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 2 | -2/+2 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 2 | -2/+16 |
| | | | | the executive. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 4 | -4/+4 |
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Changed version number. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Removed warning. | Joel Sherrill | 1999-10-21 | 2 | -0/+4 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 6 | -9/+59 |
