* | First cut at implementing time, clock_gettime, clock_settime, clock_getres, | Joel Sherrill | 1996-05-30 | 4 | -34/+336 |
| | | | | | sleep, and nanosleep. Does not yet support per process clock, per thread clock, interruptible sleep (sleep/nanosleep), or time remaining on nanosleep. | ||||
* | added dummy versions of __kill and __getpid which assert(0) so that | Joel Sherrill | 1996-05-30 | 3 | -0/+69 |
| | | | | | applications which use only the rtems api (i.e. not the posix api) will link. | ||||
* | Eric Norum sent in new versions of the inline assembly macros which | Joel Sherrill | 1996-05-30 | 2 | -82/+17 |
| | | | | do not generate warnings for unitialized variables. | ||||
* | tests now specify whether they are using rtems initialization tasks | Joel Sherrill | 1996-05-30 | 58 | -0/+116 |
| | | | | or posix initialization threads | ||||
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 103 | -51/+327 |
| | | | | or rtems initialization table in configuration table | ||||
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 8 | -88/+90 |
| | | | | tasks table" | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 31 | -62/+39 |
* | types.c: spacing | Joel Sherrill | 1996-05-29 | 4 | -56/+66 |
| | | | | | psignal.c: kill recognizes SIGABRT and exits to prevent asserts from recursively occurring because kill was not implemented and asserted. | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 3 | -6/+66 |
* | simple version of test which shows pthread_create, pthread_exit, and exit | Joel Sherrill | 1996-05-29 | 6 | -8/+38 |
| | | | | are basically working. This test will be enhanced further. | ||||
* | added pthread_exit | Joel Sherrill | 1996-05-29 | 2 | -16/+90 |
| | | | | first posix thread ran | ||||
* | cleaned up spacing and parentheses | Joel Sherrill | 1996-05-29 | 3 | -6/+6 |
* | spacing | Joel Sherrill | 1996-05-29 | 2 | -0/+2 |
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 5 | -17/+153 |
* | addressed minimum stack size attribute. | Joel Sherrill | 1996-05-29 | 2 | -2/+8 |
| | | | | | | | There is a potential problem if setting PTHREAD_STACK_MIN to 0 does not work with all applications since it is in limit.h over in newlib. There is a potential build order issue with newlib needing to know the rtems cpu dependent stack size minimum. | ||||
* | *** empty log message *** | Joel Sherrill | 1996-05-29 | 2 | -0/+6 |
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 19 | -84/+60 |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 3 | -6/+24 |
| | | | | threads table structure | ||||
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 3 | -9/+21 |
| | | | | RTEMS initialization tasks. | ||||
* | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 1996-05-29 | 6 | -154/+62 |
| | | | | should do in their place. It now compiles and links. | ||||
* | Added default POSIX API configuration table. | Joel Sherrill | 1996-05-29 | 2 | -2/+26 |
* | It is now not an error to have 0 RTEMS initialization tasks since you could | Joel Sherrill | 1996-05-29 | 2 | -0/+12 |
| | | | | create POSIX initialization threads. | ||||
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 10 | -14/+238 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 137 | -333/+559 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 3 | -3/+3 |
* | added enumerated constant for the POSIX API as an error source | Joel Sherrill | 1996-05-28 | 3 | -3/+6 |
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 8 | -10/+316 |
* | This commit was generated by cvs2svn to compensate for changes in r311, | Ralf Corsepius | 1996-05-28 | 1 | -0/+675 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 1996-05-28 | 1 | -0/+675 |
* | | new file | Joel Sherrill | 1996-05-28 | 2 | -0/+144 |
* | | commented out interrupt support | Joel Sherrill | 1996-05-28 | 3 | -0/+6 |
* | | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 3 | -3/+18 |
* | | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 4 | -2/+10 |
| | | | | | | | | deleted a blank line in rtemsapi.c | ||||
* | | comment cleanup | Joel Sherrill | 1996-05-28 | 4 | -8/+4 |
* | | added maximum keys | Joel Sherrill | 1996-05-28 | 3 | -0/+3 |
* | | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 6 | -3/+147 |
| | | | | | | | | only the rtems api don't have to include it. | ||||
* | | fixed typo | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1996-05-28 | 2 | -2/+2 |
| | | | | | | | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | ||||
* | | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 44 | -162/+489 |
* | | new file | Joel Sherrill | 1996-05-24 | 28 | -0/+674 |
* | | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 2 | -2/+2 |
* | | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 1996-05-24 | 11 | -0/+1427 |
| | | | | | | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | | changed joel's email address | Joel Sherrill | 1996-05-24 | 1 | -4/+4 |
* | | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 |
* | | new file | Joel Sherrill | 1996-05-24 | 2 | -0/+100 |
* | | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 4 | -0/+4 |
* | | new files | Joel Sherrill | 1996-05-24 | 6 | -8/+222 |
* | | updates to fix typos | Joel Sherrill | 1996-05-24 | 4 | -48/+42 |
* | | new file | Mark Johannes | 1996-05-24 | 2 | -0/+44 |
* | | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 14 | -0/+116 |
