Certain input parameters for MMU mapping operations could cause an
infinite recursion if block end boundaries didn't align to 4k. This
ensures that recursion descent does not exceed 2 levels and instead
rounds up to the nearest 4k block if necessary.
This moves the AArch64 MMU memory type definitions into cpukit for use
by libdebugger since remapping of memory is required to insert software
breakpoints.
The N used in the breakpoint and watchpoint register names is intended
to be an integer between 0 and 15 (inclusive) and will not compile when
used as is. This adds the accessors necessary to access all of these
breakpoint and watchpoint registers.
Use uintptr_t instead of DB_UINT when the variable in question describes
a pointer.
Compare the function result instead of the function pointer for non-SMP
builds.
Add a test to verify that mapping of machine exceptions to POSIX signals
operates properly when the application requests it.
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
Add a test to verify that intercepted exceptions can be resolved and
execution can be resumed.
This adds the function implementations necessary to add exception
extensions support to AArch64.
This adds the set of functions necessary to allow more generic handling
of machine exceptions. This initial patch offers the ability to
manipulate a CPU_Exception_frame and resume execution using that
exception information with or without thread dispatch. These functions
are gated behind the RTEMS_EXCEPTION_EXTENSIONS configuration option.
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with
uintptr_t, which will work for both 32 and 64 bit architectures. Added
hex_decode_addr function to rtems-debugger.
This error condition no longer exists.
Update #4528.
Move a code block to the new function _Thread_Scheduler_withdraw_nodes()
to ease code review.
Mention that resetting the processor usage time of tasks has no impact
on the period status and statistics.
Remove no longer relevant RTEMS_NOT_DEFINED error status.
Update #4528.
Update #4524.
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
Update #4524.
Closes #4533
The spconfig01 and spmisc01 tests were disabled for all AArch64 BSPs due
to a toolchain issue preventing them from compiling correctly. The
binutils version that contains the fix has been released and integrated
into RSB such that these two tests now build and operate correctly.
This reworks the existing MicroBlaze architecture port and BSP to
achieve basic functionality using the latest RTEMS APIs.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Do not use a direct thread dispatch in
_Thread_queue_Surrender_priority_ceiling() since it may be used in condition
variables using POSIX mutexes.
Close #4526.
Updates #2452.
Commit 18c8a270c296addff87f96b8c248f27eba31c24f removed
_Thread_queue_Do_nothing_extract() so we have to check for a non-NULL
queue in all configurations.
Set the postponed jobs count to zero in rtems_rate_monotonic_cancel() so that
rtems_rate_monotonic_get_status() returns a consistent status for inactive
periods.
Update #4511.
The schedule operation is only called by rtems_task_mode(). It is
called if preempt mode of the executing thread changes from disabled to
enabled. Since the EDF SMP scheduler does not support the disabled
preemption mode, the schedule operation is never called.
Write the documentation from scratch.
Clarify group description.
Update #3706.
Define the group in the header file which is used by <rtems/confdefs.h>.
Update #3706.
Update #3706.
Update #3706.
Update #3706.
Update #3706.
The utimbuf structs in fsimfsconfig01 and fsimfsconfig02 were
being passed to utime uninitialized. This did not cause problems until
utime was changed to use utimensat behind the scenes. Now that
utimensat is called, the values of the utimbuf struct are checked, and
EINVAL is set for invalid values. The utimebuf structs in these tests
could contain invalid values since they are uninitialized.
By zero-initializing the utimbuf structs, we ensure that they pass the
checks in utimensat and that errno is set to the expected ENOTSUP.
All other architectures use uint32_t for interrupt levels and there is
no reason not to do so on AArch64.
Context validation for AArch64 was ported from the ARM implementation
without a reinterpretation of the actual requirements. The spcontext01
test just happened to pass because the set of scratch registers in ARM
is a subset of the scratch registers in AArch64.
Replace the boolen return value with the new enum
Thread_queue_Deadlock_status. This improves the code readability.
Improve documentation. Shorten function names.
For uniprocessor configurations, this patch removes dead code in the
_Thread_queue_Surrender() and _Thread_queue_Surrender_priority_ceiling()
functions.
Dead code is removed from _Thread_queue_Surrender_sticky().
This function was unused. It was a relict of the thread queue rework done
during the SMP support development. In an early stage, the extract operation
was called with a NULL thread queue. However, this is no longer the case. The
extract operation is only called if we have a non-NULL thread queue.
Reflect renamed specification item.
Adjust parameter names to match with the declaration. This avoid using
a name reserved by the C standard: "time".
Close #4035.
Close #2548.
