* shared/ppc.h: mpc8260 has double FPU not single FPU.
* new_exception_processing/cpu_asm.S: Support double or single
precision context switches. Note that doing a single precision
context save/restore on a double precision PowerPC machine does not
only result in rounding errors but also screws up the FPSCR register!
* ChangeLog: Added missing lines about simcpu32.cfg and sim68000.cfg.
* custom/ts_386ex.cfg: Remove make-target-options.
* configure.ac: Add RTEMS_BSPOPTS_*(LOAD_RTC_AT_START),
RTEMS_BSPOPTS_*(BSP_DEBUG), RTEMS_BSPOPTS_*(UARTDEBUG),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* aclocal/bspopts.m4: New file.
* configure.ac: Add bspopts.h.
* include/.cvsignore: Add stamp-h* and bspopts.h*.
* include/Makefile.am: Add bspopts.h.
* pci/Makefile.am: Append -O2 to AM_CFLAGS.
* custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options.
* custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options,
re-adopt mcp750.cfg's make-exe.
* include/Makefile.am: Fix TMPINSTALL_FILES to make automake-1.5
happy.
* include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032
compatibility to make simsh happy.
* bootloader/Makefile.am: completely reworked.
* configure.ac: Add AM_PROG_AS.
* COPYING: Test of $Id$ -> $RTEMS$.
* custom/helas403.cfg, custom/gen405.cfg: Removed dependency on
the --srec-len argument to objcopy only supported in binutils 2.11
or newer.
* Makefile.am: Made to compile again.
* startup/linkcmds: Added _init, and _fini symbols.
* .cvsignore: New file.
process was captured as PR50.
* custom/gen405.cfg: New file.
* custom/helas403.cfg: Modified to generate Srecords.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* vectors/align_h.S: Added ppc405 support.
* startup/spurious.c: Added ppc405 support.
* include/bsp.h: Increase the interrupt stack size to 16K.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
This modification is a submission of the modifications necessary to
* acinclude.m4: Added gen405 BSP.
* ChangeLog: Removed bogus comment on edit of generated file.
* aclocal.m4: Added gen405 BSP.
* shared/asm.h, shared/ppc.h: Added PPC405 support.
* README.configure: Added gen405 BSP.
This fix is response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* tm27/task1.c: Account for overhead in starting and stopping
the timer.
This fix is in response to test results reported by Jerry Needell
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR49.
* src/imfs/imfs_directory.c: Do not calculate the offset twice.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63.
* psxstat/test.c: Fix test ENOTDIR to correspond to chdir() change.
Since we check permissions before evaluating enough to see if it
a regular file or directory, this hack is needed to make the regular
file executable.
* libc/chdir.c: Check for search/execute permissions on chdir.
This requires passing RTEMS_LIBIO_PERMS_SEARCH to
rtems_filesystem_evaluate_path().
* configure.ac: Delete the commented out line that said that
the mpc8260 used the old exception processing model. This line
also appears to have caused ppc603e to miss this test.
* startup/Makefile.am: Do NOT use the standard bootcard.c.
NOTE: With this fix all test including the mptest ran as expected.
Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
but discovered independently.
* mp03/delay.c: Dispatch disable level is actually 1 not 0.
* mp13/system.h: Configure enough tasks (CONFIGURE_MAXIMUM_TASKS=3).
* mp14/delay.c: Dispatch disable level may be arbitrarily > 0.
Discovered while fixing PR36 reported by Todor.Todorov@barco.com.
* include/rtems/itron/object.h: Corrected _ITRON_Objects_Get()
to use _Objects_Get_by_index().
Reported by Todor.Todorov@barco.com and tracked as PR36.
* include/rtems/score/object.h: Added prototype for
* src/objectget.c, src/objectgetisr.c: Corrected procedure for
getting index from Id so it is correct and optimal for both single
and multiprocessor configurations.
* sp26/system.h: Properly account for stack memory used by
this test. Reported by Jerry Needell <jerry.needell@unh.edu>
and processed as PR78.
* rtems++/Makefile.am: Make sure debug variant of librtems++
is linked against. Reported by Jerry Needell <jerry.needell@unh.edu>
* VERSION: New file.
* src/m68k/rdbg_cpu_asm.S: Now compiles on ColdFire.
* start/start.S: Use __mcpu32__ instead of mcpu32 and change sense
of conditional so cpu32 does not attempt to use 68000 style
interrupt vectoring.
* custom/sim68000.cfg: Generate symbols off executable not Srecords.
* Adopt more automake rules:
* automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE;
Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc;
Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS;
* automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply
CXXLINK_APP in make-cxx-exe.
* automake/lib.am: Add ARFLAGS.
* network/Makefile.am: Fix improper use of $(srcdir) in VPATH.
* startup/linkcmds: Remove explicit force of output format.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
