* setup.def: Switched to binutils 2.13.1
* binutils/Makefile.am: Remove a29k-rtems.
* custom/edb7312.cfg: New file.
* acinclude.m4: Added edb7312.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
* intr_NOTIMES.t: Real version submitted.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
* network/cs8900.c: I don't know why we have to SelfST register
twice on the EDB7312, but it doesn't work on the EDB7312 if we don't.
* src/regionreturnsegment.c: When RTEMS_REGION_SHRED_ON_FREE is
set, there should have been an & in front of size.
* Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR.
* compilers/gcc-target-default.cfg: Remove obsolete reference to
src/libxil/Makefile.
Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc
-spec).
* configure.ac: Generate unixsize.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* rtems/score/.cvsignore: unixsize*
* compilers/gcc-target-default.cfg: Add -qrtems-debug handling.
* custom/default.cfg: Remove RTEMS_BSP_SPECS. Remove reference to
obsolete Makefile.
* leaf.cfg: Various changes to LIBVARIANT processing.
* main.cfg: Ditto.
* configure.ac: Remove make/compilers/Makefile.
* Makefile.am: Add compilers/*.
* compilers/Makefile.am: Remove.
* lib.cfg: Remove.
* directory.cfg: Remove.
* README: Remove.
* VERSION: Updated to rtems-ss-20021111.
* aclocal/version.m4: Updated to rtems-ss-20021111.
* setup.def, gcc3newlib/gccnewlib.add: Patch includes updates
which were patch changes for -3 and -4 RPM revisions. Disabled
build of gnat for i386-rtems as it failed to build.
* src/mount.c: Per PR297, correct fs_mountme failure paths.
* sys/select.h: Add C++ to C external.
* automake/compile.am: Remove rel rule.
* rtems/Makefile.am: Reworked.
* sapi/Makefile.am: Reworked.
* rel.am: New.
* configure.ac: Only symlink leaf.cfg.
* startup/linkcmds: Include all .rodata* sections.
* Makefile.am: Merge in include/Makefile.am.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* TOOL_TARGETS: Updated.
* PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed
since they were obsolete.
paths.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* directory.cfg: Ditto.
* lib.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* Makefile.am: Add Templates/*.
* Templates/Makefile.am: Remove.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
Further preparations for autoconf > 2.52:
* aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else.
* aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg.
* aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* src/psignal.c: Fix counting problem which resulted in too many
entries being in the POSIX signals default behavior table.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* acinclude.m4: Adapations to autoconf > 2.52.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* src/_servtgt.c: Removed warning by adding support for ITRON
tasks and rolling multiple loops into 1.
* src/m68k/rdbg_f.c: Removed warning.
* console/console.c, network/network.c: Removed warnings.
* irq/irq.c: Removed warnings.
* network/network.c: Removed warnings.
* src/rpc/pmap_rmt.c: Removed warnings.
