* | powerpc/mvme5500/vectors/exceptionhandler.c: Turn off deprecated warning | Joel Sherrill | 2015-03-17 | 1 | -0/+6 |
| | | | | updated #2306. | ||||
* | sptests misc: Update to not use deprecated methods | Joel Sherrill | 2015-03-17 | 6 | -18/+18 |
* | tests misc: Disable deprecated method usage warning when intentional | Joel Sherrill | 2015-03-17 | 5 | -195/+232 |
| | | | | | These tests intentionally use the deprecated method. Eventually this code in the sections can be deleted. | ||||
* | Disable deprecated warning on implementation of deprecated methods | Joel Sherrill | 2015-03-17 | 8 | -4/+46 |
* | libmisc/monitor/mon-task.c: Disable deprecated warning for use of notepads | Joel Sherrill | 2015-03-17 | 1 | -2/+21 |
* | libchip/network/if_fxp.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -7/+4 |
* | libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | score603e/tod/tod.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | beatnik/network/porting/if_xxx_rtems.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | mvme167/network/network.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -19/+21 |
* | mvme162/tod/tod.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | tm07: Split some code into new spnotepad02. | Joel Sherrill | 2015-03-17 | 10 | -22/+116 |
| | | | | | | Use of deprecated notepads in sp07 needs further work. Updates #2305. | ||||
* | testsuites/samples/minimum/init.c: Notepads no longer need to be disabled | Joel Sherrill | 2015-03-17 | 1 | -7/+0 |
| | | | | They are disabled by default as they are deprecated. | ||||
* | cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification | Joel Sherrill | 2015-03-17 | 2 | -3/+3 |
* | bsp/mpc55xx: Fix flash settings | Sebastian Huber | 2015-03-17 | 1 | -13/+16 |
* | testsupport: Add worker setup handler | Sebastian Huber | 2015-03-17 | 4 | -24/+96 |
| | | | | Add rtems_test_parallel_get_task_id(). | ||||
* | bsp/qoriq: Add register blocks for T variants | Sebastian Huber | 2015-03-17 | 1 | -78/+84 |
* | bsp/qoriq: Fix warning | Sebastian Huber | 2015-03-17 | 1 | -0/+3 |
* | score: Ensure properties of CPU_Uint32ptr | Sebastian Huber | 2015-03-17 | 1 | -0/+10 |
* | cpukit: add and use CPU_Uint32ptr type | Gedare Bloom | 2015-03-16 | 21 | -2/+61 |
* | bsp/mbx8xx: Fix warnings | Sebastian Huber | 2015-03-16 | 1 | -4/+6 |
* | IMFS: don't strlen() an unterminated string in IMFS_dir_read(). | Jamie Iles | 2015-03-16 | 1 | -1/+1 |
| | | | | | | | | | a43a3466 (IMFS: Implement variable length node names) introduced a changed to IMFS_jnode_t from being a null terminated string to a separate unterminated string and length. IMFS_dir_read() was still performing a strlen() on this unterminated string though and when doing an 'ls' in the fileio example I saw that some filenames had garbage suffixes. | ||||
* | shell: remove rtems ifdef, upstream is correct | Gedare Bloom | 2015-03-16 | 1 | -8/+0 |
* | shell: fix printf warnings | Gedare Bloom | 2015-03-16 | 1 | -4/+5 |
* | capture: fix warnings in print | Gedare Bloom | 2015-03-16 | 1 | -4/+6 |
* | rtems: make error codes uintptr_t | Gedare Bloom | 2015-03-16 | 1 | -1/+1 |
* | rfs: cast minor to uintptr_t to truncate explicitly | Gedare Bloom | 2015-03-16 | 1 | -2/+2 |
* | preliminary Raspberry Pi Model 2 support | Alan Cudmore | 2015-03-16 | 6 | -22/+55 |
| | | | | | | | | | | | | | | | | | This patch adds a BSP variant for the Raspberry Pi 2. You can build both variants by configuring with the option --enable-rtemsbsp="raspberrypi2 raspberrypi" For the current BSP, the only change was the peripheral register base address and the compiler options. The raspberrypi/make/custom rules were re-factored: raspberrypi.inc -- Common rules raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+) and Pi 2. | ||||
* | tmtests/tmfine01: New test | Sebastian Huber | 2015-03-16 | 6 | -0/+2612 |
* | score: Add _Objects_ISR_disable_and_acquire() | Sebastian Huber | 2015-03-15 | 1 | -7/+22 |
* | bsps/sparc: Fix linker section | Sebastian Huber | 2015-03-15 | 1 | -3/+3 |
* | Revert "autoconf changes" | Ben Gras | 2015-03-14 | 2 | -4/+4 |
| | | | | | | This reverts commit dbe85952f9adac28a2dc84473eac24ae2c85e260. Accidentally merged. | ||||
* | beagle bsp: delete TIMER_FREQ, TIMER_COUNT | Ben Gras | 2015-03-14 | 1 | -4/+0 |
| | | | | | | unused and poorly named (no prefix) and colliding with sp68. Closes #2302. | ||||
* | autoconf changes | Ben Gras | 2015-03-14 | 2 | -4/+4 |
* | score/or1k: Fix warnings. Add missing prototypes | Hesham ALMatary | 2015-03-13 | 1 | -0/+4 |
| | | | | Closes #2304 | ||||
* | m32cbsp: Add bsp_reset() so the BSP exits | Joel Sherrill | 2015-03-12 | 2 | -1/+3 |
* | posix/src/nanosleep.c: Address issue when delay is longer than desired | Joel Sherrill | 2015-03-12 | 1 | -16/+27 |
| | | | | | | | This resulted in the elapsed time going below 0 and an arbitrarily large number returned as the time remaining. closes #2296. | ||||
* | posix: Return error code if mmap is used | Daniel Cederman | 2015-03-12 | 1 | -1/+1 |
* | posix: Move function to file with matching name | Daniel Cederman | 2015-03-12 | 2 | -10/+10 |
| | | | | mmap was previously in munmap.c and munmap was in mmap.c. | ||||
* | confdefs.h: Improve the Doxygen | Joel Sherrill | 2015-03-11 | 1 | -121/+780 |
* | mvme147s: Install z8530.h | Joel Sherrill | 2015-03-11 | 2 | -0/+13 |
| | | | | This was missed when the file was moved. | ||||
* | cpukit/include/rtems/btimer.h: Add DOxygen comments | Joel Sherrill | 2015-03-11 | 1 | -2/+56 |
* | cpukit/include/rtems/bspIo.h: Add Doxygen comments | Joel Sherrill | 2015-03-11 | 1 | -29/+107 |
* | cpukit: Remove old DESCRIPTION: in comments | Joel Sherrill | 2015-03-11 | 12 | -131/+24 |
| | | | | These were remnants of pre-Doxygen comment style. | ||||
* | doc/started: simplify and fix | Gedare Bloom | 2015-03-11 | 8 | -1226/+47 |
| | | | | | | | | | | | | * fix and remove some macros in rtems.texi.in. * refer to devel mailing list. * remove reference to Debian packaging in requirements section. * remove section on prebuilt tools. * replace toolset build instructions with link to RSB docs. * Add a note in building RTEMS section about using RSB. * Fix URLs Closes #2291. | ||||
* | cpukit: deprecate task variables. closes #2293. | Gedare Bloom | 2015-03-10 | 4 | -4/+26 |
* | cpukit: deprecate rtems_clock_get(). closes #2294. | Gedare Bloom | 2015-03-10 | 2 | -1/+6 |
* | cpukit: deprecate notepads | Gedare Bloom | 2015-03-10 | 13 | -16/+77 |
| | | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265 |
