Call bsp_work_area_initialize() before bsp_start(). This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
Move content to bsp_predriver_hook() functions of the BSPs.
Update #2408.
Drop the superfluous parenthesis since this confuses the C++ compiler of
some GCC versions. See also
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=67064
Fix broken RTEMS linker set description introduced by
b618d8cfc54f84d4ed03dc7b7fa510c872e6128a.
Fix broken RTEMS linker set descriptions introduced by
updates #2457.
Updates #2458.
closes #2444.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
closes #2445.
Update #2477.
Close #2477.
The expensive heap walks are superfluous due to the heap protection
enabled via RTEMS_DEBUG.
Update #2477.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
This function is used by Newlib since 2013-07-09 (Git commit
9b51cd8c6b9cdd067d9648a7ab952884019c56a5).
This structure is available in Newlib since 2013-11-29 (Git commit
a534dfd26e765047621acd0eda656ded886e7108).
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
If filesystem object already exists at extracted directory path
then if it is directory, creation is ignored. Attempt
to delete/unlink object and make directory is tried for other cases.
This simple approach problem reported in ticket fixes #2413.
Behavior follows GNU tar and BSD tar practice for directories
but much more work is required to achieve full semantics
of the full featured tar implementation still.
remarks.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
boot loader.
The default tms570ls3137_hdk variant is for building RTEMS
application image starting directly from start of Flash.
Variant tms570ls3137_hdk_with_loader skips 256kB at start
of Flash to allow use with application loader.
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
tms570_sci_interrupt_last_close: do not wait for old data transmit.
Required by new network stack.
We must not load registers (e.g. PSR) from the heir context area before
the heir stopped execution.
With this patch the write to PSR is divided into two steps. We first update
the current window pointer and then we restore the status registers and
enable traps. This allows us to move the first write to PSR to be before
the write to WIM, as there is now no risk that we get an interrupt where
the CWP and WIM would be inconsistent. We only need to make sure that we
do not use any of the non-global registers or instructions that affects
CWP for three instructions after the write.
In the earlier code the non-global %o1 register was used right after the
write to PSR, which required the use of three nop:s.
Update via:
wget -O config.guess 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD'
wget -O config.sub 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD'
We must ensure that the Thread_Control::Wait information update is
visible to the target thread before we update its wait flags, otherwise
we may return out of date events or a wrong status.
