* | Added information on how the directory is stored for future referance | Jennifer Averett | 1999-10-25 | 1 | -2/+3 |
| | | | | during a mount. | ||||
* | Formatting improvements. | Joel Sherrill | 1999-10-25 | 3 | -12/+80 |
* | Enabled Ada95 interrupt support chapter and reformatted a | Joel Sherrill | 1999-10-25 | 6 | -35/+48 |
| | | | | bunch of stuff to avoid line wrappings. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> to address the following problem | Joel Sherrill | 1999-10-25 | 3 | -3/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 2 | -0/+16 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Added notes for new test. | Joel Sherrill | 1999-10-25 | 1 | -0/+19 |
* | Made html links browsable. | Charles Phillips | 1999-10-25 | 1 | -4/+3 |
* | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 3 | -73/+73 |
| | | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | ||||
* | Made urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
* | Made html urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Made html urls browable links. Updated the reference to the | Charles Phillips | 1999-10-25 | 1 | -6/+48 |
| | | | | | U.S. Army Missile Command to show the merger with the Aviation Command | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 4 | -28/+32 |
| | | | | <raguet@crf.canon.fr> to use a local variable. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 6 | -216/+222 |
| | | | | process. | ||||
* | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 1999-10-25 | 10 | -122/+82 |
* | Changed to use interrupt driven console. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 14 | -2/+582 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 8 | -2184/+2184 |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 2 | -2/+2 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 2 | -2/+16 |
| | | | | the executive. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 4 | -4/+4 |
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Changed version number. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Removed warning. | Joel Sherrill | 1999-10-21 | 2 | -0/+4 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 6 | -9/+59 |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 14 | -9/+27 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Now can specify rpm_build_root via setup. | Joel Sherrill | 1999-10-21 | 1 | -2/+2 |
| | | | | Changed package name so generated RPM would have a nicer name. | ||||
* | Increased stack size of initialization thread. | Joel Sherrill | 1999-10-21 | 2 | -0/+4 |
* | Added rtems_semaphore_flush directive. | Joel Sherrill | 1999-10-21 | 5 | -1/+209 |
* | Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE to | Joel Sherrill | 1999-10-21 | 2 | -12/+12 |
| | | | | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads. | ||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 2 | -6/+14 |
* | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1999-10-21 | 10 | -143/+176 |
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 19 | -135/+231 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 4 | -0/+36 |
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 2 | -6/+7 |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 2 | -2/+24 |
| | | | | Eric Norum. | ||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 7 | -19/+42 |
| | | | | functioned. | ||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 2 | -34/+37 |
| | | | | | | functioned. Merged Ralf's changes into gccnewlib.spec.in. | ||||
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+50 |
* | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1999-10-20 | 13 | -199/+35 |
| | | | | Ralf's end of day version. | ||||
* | Moved rtems specific files into here. | Joel Sherrill | 1999-10-20 | 1 | -0/+80 |
* | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 1999-10-20 | 2 | -80/+0 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+177 |
* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 2 | -10/+25 |
* | Generated files removed. | Joel Sherrill | 1999-10-20 | 11 | -307/+155 |
* | Obsoleted. | Joel Sherrill | 1999-10-20 | 1 | -34/+0 |
* | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 1999-10-20 | 4 | -473/+0 |
* | Made this more binutils like. :) | Joel Sherrill | 1999-10-20 | 1 | -5/+9 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+104 |
* | New files. | Joel Sherrill | 1999-10-20 | 2 | -0/+285 |
