* | Update config.guess and config.sub | Sebastian Huber | 2015-11-12 | 2 | -199/+110 |
| | | | | | | | Update via: wget -O config.guess 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD' wget -O config.sub 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD' | ||||
* | libtests/termios04: Avoid use of freed memory | Sebastian Huber | 2015-11-12 | 1 | -7/+35 |
* | score: Fix race condition on SMP | Sebastian Huber | 2015-11-12 | 3 | -41/+67 |
| | | | | | | We must ensure that the Thread_Control::Wait information update is visible to the target thread before we update its wait flags, otherwise we may return out of date events or a wrong status. | ||||
* | irq-server: Fix race condition on SMP systems | Sebastian Huber | 2015-11-12 | 1 | -4/+5 |
* | Fix interrupt epilogue for ARMv7-AR and PowerPC | Sebastian Huber | 2015-11-12 | 2 | -13/+65 |
* | Introduce general purpose system server event | Sebastian Huber | 2015-11-12 | 3 | -9/+8 |
| | | | | | Use this event for the interrupt server to avoid conflicts with application events used by interrupt handlers. | ||||
* | gpio: free memory in error path | Gedare Bloom | 2015-11-09 | 1 | -11/+8 |
| | | | | Updates #2462. | ||||
* | LPC1768: Fix compilation error | Martin Galvan | 2015-11-05 | 4 | -8/+8 |
| | | | | | | | | | | The LPC1768 variants have a gpio.h file whose name clashes with the gpio.h from the new GPIO API. This results on the BSPs failing to compile. This patch renames the LPC1768 gpio.* files to lpc-gpio.*, as it's done on other BSPs (e.g. Beaglebone). Closes #2441. | ||||
* | Resurrect make/Templates/Makefile.lib | Sebastian Huber | 2015-11-05 | 1 | -0/+58 |
| | | | | | This file was accidentally removed by 370c09a1f4012139aebabb4f2c9ec081855fc94d. | ||||
* | bsp/irq-server: Use proper chain API | Sebastian Huber | 2015-11-05 | 1 | -5/+9 |
* | sapi: Add rtems_chain_get_first_unprotected() | Sebastian Huber | 2015-11-05 | 3 | -0/+50 |
| | | | | Close #2459. | ||||
* | score: Fix warning | Sebastian Huber | 2015-11-04 | 1 | -1/+1 |
| | | | | Close #2454. | ||||
* | sptests/spsimplesched02: Fix warning | Sebastian Huber | 2015-11-04 | 1 | -1/+1 |
| | | | | Close #2455. | ||||
* | Add STM32F7 HAL Files | Isaac Gutekunst | 2015-11-03 | 164 | -0/+173200 |
| | | | | | These files originated as: + STC32CubeF7 V1.1.0 from http://www.st.com/web/en/catalog/tools/PF261909 | ||||
* | Add STM32F4 HAL Files | Isaac Gutekunst | 2015-11-03 | 181 | -58/+285081 |
| | | | | | The origin of this code is: + STM32CubeF4 V1.8.0 from http://www.st.com/web/en/catalog/tools/PF259243 | ||||
* | Leftover gpio function rename | Ben Gras | 2015-11-03 | 2 | -4/+4 |
| | | | | | | Rename rtems_bsp_select_specific_io to rtems_gpio_bsp_select_specific_io. Should've gone with 5c337d7. Fixes #2456. | ||||
* | libblock: Print block sizes and count | Sebastian Huber | 2015-11-02 | 5 | -2/+27 |
* | libblock: Avoid NULL pointer access | Sebastian Huber | 2015-11-02 | 1 | -1/+3 |
* | ada: Add missing include | Jan Sommer | 2015-10-30 | 1 | -0/+1 |
| | | | | | Include stackimpl.h otherwise PTHREAD_MINIMUM_STACK_SIZE cannot be evaluated. | ||||
* | bsp/qoriq: Fix interrupt support for T series | Sebastian Huber | 2015-10-28 | 3 | -127/+77 |
* | bsp/qoriq: Add BMan, QMan and FMan to memory map | Sebastian Huber | 2015-10-28 | 1 | -1/+20 |
* | bsp/qoriq: Flush and invalidate L2 cache | Sebastian Huber | 2015-10-28 | 2 | -0/+27 |
* | bsp/qoriq: Invalidate L1 cache on boot processor | Sebastian Huber | 2015-10-28 | 1 | -0/+20 |
* | bsp/qoriq: Map intercom area only if necessary | Sebastian Huber | 2015-10-28 | 1 | -1/+3 |
* | bsp/qoriq: Add BMan and QMan portals to memory map | Sebastian Huber | 2015-10-28 | 3 | -4/+11 |
* | bsp/qoriq: Increase non-cacheable region | Sebastian Huber | 2015-10-28 | 1 | -2/+2 |
* | bsp/qoriq: Drop M flag from device IO regions | Sebastian Huber | 2015-10-28 | 1 | -1/+1 |
* | bsps: Generalize .nocacheheap to .nocachenoload | Sebastian Huber | 2015-10-28 | 6 | -5/+25 |
| | | | | Add ability to place data in a non-loadable cache-inhibited area. | ||||
* | powerpc: Add FSL cache defines | Sebastian Huber | 2015-10-28 | 1 | -0/+10 |
* | CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error checked | Joel Sherrill | 2015-10-27 | 3 | -2/+71 |
| | | | | closes #2431. | ||||
* | basdefs.h: Add and use RTEMS_PACKED | Sebastian Huber | 2015-10-26 | 6 | -23/+26 |
* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 127 | -291/+330 |
* | basdefs.h: Add and use RTEMS_DEPRECATED | Sebastian Huber | 2015-10-26 | 10 | -20/+22 |
* | basdefs.h: Add RTEMS_PURE | Sebastian Huber | 2015-10-26 | 1 | -3/+5 |
* | basedefs.h: Add and use RTEMS_NO_RETURN | Sebastian Huber | 2015-10-26 | 33 | -44/+46 |
* | basedefs.h: Add compiler attributes | Sebastian Huber | 2015-10-26 | 1 | -1/+40 |
* | RFS: Fix resource leak | Sebastian Huber | 2015-10-26 | 1 | -0/+2 |
| | | | | Close #2433. | ||||
* | Fail gracefully if pax is not found | Ben Gras | 2015-10-22 | 1 | -1/+5 |
| | | | | | The $(PAX) variable is used unconditionally so it shouldn't be left empty if not found at configure time. Fixes #2437. | ||||
* | Fixes GPIO APIs Naming Convention and Comments | Sudarshan Rajagopalan | 2015-10-21 | 4 | -17/+21 |
| | | | | Closes #2435. | ||||
* | libbsp/Makefile.am: gpio.h as preinstalled header | Ben Gras | 2015-10-21 | 2 | -0/+5 |
| | | | | Also regenerate preinstall.am. Closes #2434. | ||||
* | moxiesim/configure.ac: Fix typo | Joel Sherrill | 2015-10-20 | 1 | -1/+1 |
| | | | | updates 2254. | ||||
* | h8sim-testsuite.tcfg: Add fsdosfsname01 | Joel Sherrill | 2015-10-20 | 1 | -0/+1 |
| | | | | closes #2432. | ||||
* | bsp/leon3: Fix Termios context usage | Sebastian Huber | 2015-10-20 | 1 | -8/+3 |
| | | | | | Only the context of the console device was used and this is wrong in case more than one APBUART device is available. | ||||
* | bsp/qoriq: Use U-Boot provided FDT | Sebastian Huber | 2015-10-19 | 10 | -42/+268 |
* | libfdt: Merge into librtemscpu | Sebastian Huber | 2015-10-19 | 4 | -17/+3 |
| | | | | This allows BSPs to use this library. | ||||
* | bsp/qoriq: Simplify initialization | Sebastian Huber | 2015-10-19 | 1 | -75/+62 |
* | bsp/qoriq: Initialize FPU on secondary thread | Sebastian Huber | 2015-10-19 | 1 | -0/+4 |
* | libfdt: Initial import | Sebastian Huber | 2015-10-16 | 28 | -0/+4529 |
| | | | | | | | | | | | | | | Import from: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Commit: 604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e Date: 2015-09-29T09:09:08Z | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2015-10-15 | 4 | -8/+0 |
| | | | | This define accidentally re-appeared. | ||||
* | bsp/qoriq: Add missing isync after mtmsr | Sebastian Huber | 2015-10-15 | 1 | -0/+4 |
