- Remove TargetInfo from app_common
- Created the targetInfo_m member variable in CoverageReaderBase,
TraceWriterBase, and ObjdumpProcessor
- Made functions to set the value of targetInfo_m
- Removed SymbolsToAnalyze from app_common and replaced it with the
symbolsToAnalyze_m member variable in DesiredSymbols, GcovData, and
ObjdumpProcessor
- Added a parameter to constructors to initialize symbolsToAnalyze_m
- Moved the definition of objdumpLine_t out of ObjdumpProcessor to make
it work with DesiredSymbols
Replaced Verbose in app_common with local variables that are passed
as a parameter into numerous functions
Use rld tempfile for temporary files and add fatal signal handling to clean
them up in the event of a crash.
Use waf to build covoar.
