* | fix _mkdir parameter error. | zhengxiaojun | 2022-11-28 | 1 | -1/+1 |
| | | | | | | fix _mkdir parameter error. Signed-off-by: zhengxiaojun <jameszxj at gmail.com> | ||||
* | ReportsBase: Change raw pointer to unique_ptr | Ryan Long | 2021-12-22 | 1 | -41/+36 |
| | | | | | | | | Replaced raw pointer used with ReportsBase-derived classes to make code cleaner and make it to where pointers do not have to be manually deleted. Closes #4376 | ||||
* | TraceConverter.cc: Fix Uncaught exception issue | Ryan Long | 2021-12-15 | 1 | -3/+27 |
| | | | | | | CID 1471639: Uncaught exception Closes #4501 | ||||
* | SymbolTable.cc: Fix formatting | Ryan Long | 2021-12-15 | 1 | -32/+38 |
* | ObjdumpProcessor.h: Fix formatting | Ryan Long | 2021-12-15 | 1 | -12/+10 |
* | ObjdumpProcessor.cc: Fix formatting | Ryan Long | 2021-12-15 | 1 | -86/+111 |
* | ConfigFile: Fix formatting | Ryan Long | 2021-12-15 | 2 | -37/+37 |
* | TargetFactory.cc: Fix formatting | Ryan Long | 2021-12-15 | 1 | -11/+9 |
* | ObjdumpProcessor.cc: Fix formatting | Ryan Long | 2021-12-15 | 1 | -28/+36 |
* | ObjdumpProcessor: Convert to C++ | Ryan Long | 2021-12-10 | 2 | -15/+18 |
* | ConfigFile: Convert to C++ | Ryan Long | 2021-12-10 | 2 | -51/+33 |
* | Target: Convert to C++ | Ryan Long | 2021-12-10 | 18 | -92/+103 |
* | TargetFactory.cc: Convert to C++ | Ryan Long | 2021-12-10 | 1 | -3/+3 |
* | TraceList.cc: Convert from C to C++ | Ryan Long | 2021-12-07 | 1 | -8/+6 |
* | TraceConverter.cc: Fix formatting | Ryan Long | 2021-12-07 | 1 | -19/+21 |
* | TraceConverter.cc: Convert to C++ | Ryan Long | 2021-12-07 | 1 | -20/+19 |
* | Explanations.h: Fix formatting | Ryan Long | 2021-12-07 | 1 | -10/+4 |
* | Explanations.cc: Fix formatting | Ryan Long | 2021-12-07 | 1 | -25/+26 |
* | Explanations: Convert to C++ | Ryan Long | 2021-12-07 | 2 | -7/+7 |
* | ExecutableInfo.h: Fix formatting | Ryan Long | 2021-12-07 | 1 | -8/+8 |
* | ExecutableInfo.cc: Fix formatting | Ryan Long | 2021-12-07 | 1 | -45/+58 |
* | TraceConverter.cc: Add final catch for exceptions | Ryan Long | 2021-11-30 | 1 | -3/+13 |
| | | | | | | CID 1471639: Add catch for exception Closes #4501 | ||||
* | TraceConverter.cc: Add catch for exception | Ryan Long | 2021-11-04 | 1 | -4/+18 |
* | TraceConverter.cc: Add catch for exception | Ryan Long | 2021-10-13 | 1 | -16/+29 |
* | TraceConverter.cc: Add catch for exception | Ryan Long | 2021-10-08 | 1 | -7/+21 |
* | ReportsBase.cc: Add assert for member variables | Ryan Long | 2021-10-07 | 1 | -0/+5 |
| | | | | | | | | | | | The uncoveredRanges and uncoveredBranch member variables are allocated as a pair. They are both either NULL or not NULL. Coverity does not know this though, so this assert is added to ensure they are not NULL before being dereferenced. CID 1503710: Dereference after null check Closes #4428 | ||||
* | TraceWriterQEMU.h: Fix formatting | Ryan Long | 2021-09-28 | 1 | -3/+3 |
* | TraceReaderLogQEMU.h: Fix formatting | Ryan Long | 2021-09-28 | 1 | -1/+0 |
* | TraceWriterQEMU.cc: Fix formatting | Ryan Long | 2021-09-28 | 1 | -20/+26 |
* | TraceReaderLogQEMU.cc: Fix formatting | Ryan Long | 2021-09-28 | 1 | -8/+7 |
* | TraceWriter: Convert to C++ | Ryan Long | 2021-09-28 | 3 | -27/+16 |
* | TraceReader: Convert to C++ | Ryan Long | 2021-09-28 | 8 | -86/+68 |
* | CoverageRanges.cc: Fix formatting | Ryan Long | 2021-09-28 | 2 | -14/+12 |
* | GcovFunctionData.cc: Initialize member variables | Ryan Long | 2021-09-27 | 1 | -3/+7 |
| | | | | | | CID 1399640: Uninitialized pointer field Closes #4432 | ||||
* | DesiredSymbols.h: Initialize symbolInfo | Ryan Long | 2021-09-27 | 1 | -0/+1 |
| | | | | | | CID 1399627: Uninitialized pointer field Closes #4433 | ||||
* | TraceWriterQEMU.cc: Initialize header._pad | Ryan Long | 2021-09-27 | 1 | -0/+1 |
| | | | | | | CID 1506204: Uninitialized scalar variable Closes #4488 | ||||
* | TraceWriterQEMU.cc: Change strncpy to memcpy | Ryan Long | 2021-09-27 | 1 | -1/+3 |
| | | | | | | CID 1506207: Buffer not null terminated Closes #4491 | ||||
* | CoverageWriterTSIM.h: Fix formatting | Ryan Long | 2021-09-13 | 1 | -3/+3 |
* | CoverageWriterTSIM.cc: Fix formatting | Ryan Long | 2021-09-13 | 1 | -11/+11 |
* | CoverageWriterSkyeye.h: Fix formatting | Ryan Long | 2021-09-13 | 1 | -3/+3 |
* | CoverageWriterSkyeye.cc: Fix formatting | Ryan Long | 2021-09-13 | 1 | -5/+5 |
* | CoverageWriterRTEMS.h: Fix formatting | Ryan Long | 2021-09-13 | 1 | -3/+3 |
* | CoverageWriterRTEMS.cc: Fix formatting | Ryan Long | 2021-09-13 | 1 | -12/+11 |
* | covoar.cc: Fix formatting | Ryan Long | 2021-09-13 | 1 | -133/+167 |
* | CoverageWriterBase.h: Fix formatting | Ryan Long | 2021-09-13 | 1 | -3/+3 |
* | covoar.cc: Convert to C++ | Ryan Long | 2021-09-13 | 1 | -27/+23 |
| | | | | Got rid of C-strings, changed FILE pointer to ifstream. | ||||
* | CoverageWriter: Convert to C++ | Ryan Long | 2021-09-13 | 7 | -45/+59 |
* | CoverageReaderTSIM.cc: Fix formatting | Ryan Long | 2021-09-07 | 1 | -4/+6 |
* | CoverageReaderSkyeye.cc: Fix formatting | Ryan Long | 2021-09-07 | 1 | -9/+12 |
* | CoverageReaderRTEMS.cc: Fix formatting | Ryan Long | 2021-09-07 | 1 | -13/+13 |
