CID 1399640: Uninitialized pointer field
Closes #4432
CID 1506205: Not restoring ostream format
Closes #4484
Change C-style code to C++
- Removed the includes of app_common.h
- Removed app_common references in build infrastructure
- Removed app_common.cc and app_common.h
- Removed SymbolsToAnalyze from app_common and replaced it with the
symbolsToAnalyze_m member variable in DesiredSymbols, GcovData, and
ObjdumpProcessor
- Added a parameter to constructors to initialize symbolsToAnalyze_m
- Moved the definition of objdumpLine_t out of ObjdumpProcessor to make
it work with DesiredSymbols
Use waf to build covoar.
