* | CoverageReaderTSIM.cc: Fix formatting | Ryan Long | 2021-09-07 | 1 | -4/+6 |
* | CoverageReader: Convert to C++ | Ryan Long | 2021-09-07 | 1 | -10/+11 |
* | Remove app_common and all references to it | Ryan Long | 2021-08-03 | 1 | -1/+0 |
| | | | | | | - Removed the includes of app_common.h - Removed app_common references in build infrastructure - Removed app_common.cc and app_common.h | ||||
* | Remove BranchInfoAvailable global variable | Ryan Long | 2021-08-03 | 1 | -2/+2 |
| | | | | | | - Removed BranchInfoAvailable from app_common - Created member variable in CoverageReaderBase and ReportsBase and a function to get the value of the member variable | ||||
* | covoar: Eliminate tabs | Joel Sherrill | 2021-04-06 | 1 | -8/+8 |
* | tester/covoar: Remove all exit() calls and throw an rld::error exception. | Chris Johns | 2018-06-18 | 1 | -18/+21 |
| | | | | Add a suitable catch to covoar's main. | ||||
* | covoar: Merger the covoar source from rtems-testing.git. | Chris Johns | 2014-06-18 | 1 | -0/+102 |
Use waf to build covoar. |
