* | rtems/mipsstx39: Update to GDB 13.1 and stage build GMP | Chris Johns | 2023-04-05 | 1 | -11/+0 |
| | | | | | | | - Use a build set file to stage GMP as recent GDB versions require GMP. Update #4892 | ||||
* | rtems-default.bset: Update to gdb 7.12 | Joel Sherrill | 2016-11-13 | 1 | -1/+1 |
| | | | | | | Clean up comments in mipstx39 file. It doesn't build in gdb 7.12. It is fixed on the gdb master and 7.12 branch. When 7.12.1 comes out, we will need to bump to that. | ||||
* | rtems-mips.bset: Update mipstx39 GDB version to be in sync | Joel Sherrill | 2015-05-13 | 1 | -0/+11 |
