Change back to gcc-13 branch and a git version as gcc-13.2 does
not build on MacOS 14.4. The fixes are on the gcc-13 release branch.
This was driven by the increase in fdset size from 64 to 256
files.
In particular, the BSP set definitions for rtems-bsp-builder were
out of sync with RTEMS and caused unnecessary failures reported to
the build@ mailing list.
Update #4921
Updates #4969
Updates #4970
Prepare for RTEMS 6.1 release.
Update #4921.
Keep RTEMS up to date with the upstream development.
Pick up fixes for ARM/optimized-routines and the memory reclamation at thread
exit.
Update #4510.
Update #4967.
This configuration file was missing for the mipstx39 gdb build for the
head/7 tools.
Closes #4935.
Pick up the test printer header change
- Pick up fixes to x86 (i368) bus space usage in kernel DMA
- libdl: fix TLS in base image
- bsps/xnandpsu: fixes
- cpukit/jffs2: avoid dead lock
- bsps/imxrt: enable USB and fix PHY clock enable
- bsps/stm32h7: update STM32 H7 HAL
Minor fix in rtems-test
Pick up latest changes from ARM/optimized-routines.
Close 4510.
Updates #4951
Updates #4951
Updates #4920
- Pick up the Beatnik support for the legacy driver
Update #4921.
- Zynq ARM fixes
- AARCH64 MMU fix
- Updated imxrt drivers
- x86_64 EFI support
- Flash driver
- Updated validation tests
- Microblaze updates
- Add getaddrinfom, gai_strerror, ipv6_addr, if_nametoindex and BSD programs
- Update sysctl
- Move legacy net
Previously newlib only had long double math functions when the
sizeof(double) was equal to sizeof(long double). Newlib now includes
support for true long double on x86, x86_64, and aarch64.
These files were not included in the previous commit.
- Tools picks up the stm32h7-stlink to handle SIGTRAP fix.
- RTEMS picks up the motorola_powerpc updates including the mvme2700
BSP and Makefile.inc fixes for building EPICS.
- Legacy networking picks up a number of build system fixes,
network configuration changes and more tests.
- Build GNU sed for hosts that it is not installed on for the MIPS
tools.
- MacOS systems do not come with makeinfo
- Fix the internal build logic. There was config logic in a
bset file that does not support logic operators. Use a
special tmp internal path to isolate the internal tools.
- Use a build set file to stage GMP as recent GDB
versions require GMP.
Update #4892
- Use base64 checksums
- Change MPFR URL
Updates #4892
- Detect and use a virtual environment if present
- Supports MacOS with python.org in a venv
Updates #4892
Binutils 2.40 has a regression for AArch64 that has previously been
fixed. See https://sourceware.org/bugzilla/show_bug.cgi?id=27217
This regression causes at least 2 tests to fail to build.
