Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
Add support to build MinGW tools using Cygwin. This is a Canadian cross
build.
Do not expand the directives when parsing a configuration file. Hold
in the package object the text as read from the configuration file. Still
parse the logic but leave the macros. This allows a configuration to be
varied when the build happens. The Canadian cross uses this to build a
build compiler used to build a Cxc runtime.
Add Cxc support to the build module. In the defaults add rm and rmfile
macros, add Cxc paths and pre-build script code.
In the setbuilder check for a Cxc build and if so and the package
allow Cxc build the build host version then the host target
version.
Add cygiwn support to the defaults processing and to the Windows module.
Add arch build files. This allows archs to have different versions
and patches for specific tools.
Break the RTEMS config directory up into separate directories to
make long term maintenance easier. This required a change to config.py
to handle the config files being in subdirs of the config directory.
The defaults have been updated to include the install SB root so
packages built before a package are available.
Add makeinfo to the required tools. GDB (and others) need it to
build without error.
