- Move 5/bsps/* to bsps/*
- Update package build references from 5 to 6
- Remove 5 build sets.
Update #4048
Pick up fix for crt0.c.
This is primarily to pick up the bug fix to have i386 fenv methods.
This picks up fixes for at least the RTEMS reported issues for missing
extern C in devctl.h and the symlink issue with bsdtar.
Pick up <fenv.h> and FreeBSD compatiblity changes.
* Minor update from 8.2.1
* Can be built without patches (!)
- Update to SIS 2.17 which has internal readline support for
the hosts which do not have readline.
Closes #3763
Closes #3769
Pick up <stddef.h> FreeBSD compatiblity changes.
Pick up register_t changes.
Reduce Git hash length to fix Ada build issues.
Pick up FreeBSD compatibility improvements.
Update #3472.
Pick up <sys/time.h> updates from FreeBSD.
Update #3472.
Be in line with default targets.
This is a preparation to update or1k to use the latest GCC.
Update #3602.
Update #3602.
Fix v850 target issue related to the new -fdata-sections build.
Remove <machine/param.h> include from <sys/_cpuset.h>.
Fix posix_memalign() attributes.
Use -fdata-sections and -ffunction-sections to build Newlib.
Pick up POSIX header file changes and improved opendir() implementation.
This addesses time of check and time of use error conditions (TOCTOU).
Update #3530.
Update #3545.
Update #3546.
Update #3547.
Pick up POSIX header file changes for an upcomming FreeBSD baseline
update in libbsd.
Update #3472.
Close #3491.
Use the latest Newlib to fix the GCC libgomp build (TLS support was not
detected due to broken crt0).
Update #3452.
It includes a fix for bug in the ctype support, some FreeBSD
compatibility changes in <sys/cdefs.h> for libbsd and a new
configuration option for all targets newlib/configure.host which is used
by the RISC-V port.
Close #3452.
Update Binutils to include a bug fix for:
https://sourceware.org/bugzilla/show_bug.cgi?id=23451
Update #3452.
This is a temporary workaround for this bug:
It is not clear how this can be resolved upstream.
Update #3452.
After several upstream updates in Binutils, GCC, Newlib, and GDB it is
now possible to use a common riscv tool chain for the 32-bit and 64-bit
RISC-V.
Update GDB to ce73f310150418a9a1625ab60a527d959096a9e2 Git commit.
Close #3452.
