- Do not build a test if a dependency is not enabled.
- Perform a dependency check and generate an error if an enabled module
depends on a disabled module.
Closes #4077
- Provide support for separate user and kernel include paths in
libbsd.py.
- Update all added files with a suitable context to build them
with. Supported contexts are `kernel` and `user`.
- Kernel source use the kernel, CPU, and build header paths in
this order.
- User source use the user, kernel, CPU and build header paths
in this order. The FreeBSD /usr/include tree has some kernel
header files installed as well as user land header files. This
complicates the separation as some kernel header files are not
visible to user land code while other are. This is handled by
appending the kernel header paths to the user header paths so
user land code will include a user header with the same name as
a kernel header over the kernel header but will find a kernel
header if there is no matching user header file.
Closes #4067
Update #3909
Update #3351
Remove the need to generate a waf script.
Move various pieces of data from the builder code to libbsd.py and make
it configuration data.
Update #3351
Update #3220.
This allows to set the optimization level for libbsd via a configure
switch. Useful for building with for example no optimization during
debug or with size optimization for space restricted targets.
Add --freebsd-options to add specific FreeBSD compile time options to
the build. This is a developer tool.
Add support to force the RTEMS version. This remove the need for using
the --rtems-version command line option if the automatic detection fails.
Update all python code to support python 2 and 3.
Update rtems_waf to the latest version to support the RTEMS version,
check environment variables and to display the CC version.
Sort all tests. I think the unsorted list is dependent on the version
of python and so would result in repo noise as if it regenerted.
Avoid and delete this function.
Make sure that architecture specific header files are found first.
change _IP_IP ending to _IP. Remove _IP_IP ending from NET_TAP_INTERFACE.
modified: wscript
Re-generated from "./freebsd-to-rtems -m" based on
waf_generator.py
- Update the file builder generator to handle generator specific cflags and
includes. The tcpdump and libpcap have localised headers and need specific
headers paths to see them. There are also module specific flags and these
need to be passed to the lex and yacc generators.
- Add the tcpdump support.
Check for the "rtems/pci.h" header and provide conditional build support
with waf to build for BSPs that do not have PCI support. The Makefile build
always defines HAVE_RTEMS_PCI_H which is the same state with this change.
The PCI calls still exist however they do nothing and return a constant.
Any PCI based driver that makes these calls on a BSP that does not have
PCI support will not work which is understandable. Either change the
driver or add PCI support the BSP.
Install to the --prefix path passed to configure.
