* | Use rtems_task_exit() | Sebastian Huber | 2022-06-01 | 1 | -2/+2 |
* | testsuite: Use new name of test-info.h. | Christian Mauderer | 2020-07-31 | 1 | -1/+1 |
| | | | | | In RTEMS the test.h has been renamed to test-info.h to allow the new test framework to take over. | ||||
* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -4/+9 |
* | testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2020-04-03 | 1 | -1/+1 |
* | testsuite: User input define added | Moyano, Gabriel | 2020-03-31 | 1 | -1/+2 |
* | testsuite: Using RTEMS tester functions at beginning and at the end of tests | Moyano, Gabriel | 2020-03-31 | 1 | -1/+4 |
| | | | | puts() was replaced with rtems_test_begin() and rtems_test_end() | ||||
* | Fix warnings | Sebastian Huber | 2019-09-24 | 1 | -4/+3 |
* | Add tests for USB keyboard and mouse as well as EVDEV | Kevin Kirspel | 2017-05-19 | 1 | -0/+283 |
