* | testsuite: Use new name of test-info.h. | Christian Mauderer | 2020-07-31 | 1 | -1/+1 |
| | | | | | In RTEMS the test.h has been renamed to test-info.h to allow the new test framework to take over. | ||||
* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -0/+6 |
* | testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2020-04-03 | 1 | -1/+1 |
* | testsuite: Using RTEMS tester functions at beginning and at the end of tests | Moyano, Gabriel | 2020-03-31 | 1 | -2/+5 |
| | | | | puts() was replaced with rtems_test_begin() and rtems_test_end() | ||||
* | tests: Fix configuration dependencies | Sebastian Huber | 2018-02-05 | 1 | -0/+3 |
* | tests: Remove obsolete config defines | Sebastian Huber | 2017-10-20 | 1 | -4/+0 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -5/+0 |
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -0/+2 |
* | timeout01: Avoid Nexus devices | Sebastian Huber | 2013-11-13 | 1 | -0/+5 |
* | TIMEOUT(9): Use timer server for callout_tick() | Sebastian Huber | 2013-10-31 | 1 | -3/+0 |
* | Move TIMEOUT(9) and ZONE(9) initialization | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
| | | | | Delete most of virtual memory support. | ||||
* | Use extension to attach a struct thread to threads | Sebastian Huber | 2013-10-10 | 1 | -0/+2 |
| | | | | Add test thread01. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Provide SWI(9) and TIMEOUT(9) | Christian Mauderer | 2012-05-10 | 1 | -0/+81 |
