* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -0/+6 |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 1 | -275/+33 |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | ||||
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 1 | -33/+275 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 1 | -6/+0 |
| | | | | | | | | Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. | ||||
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | rwlock01: Do not print in the worker task | Sebastian Huber | 2013-12-16 | 1 | -14/+0 |
| | | | | | The worker task must not block on the console device shared with the master task. | ||||
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -10/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -1/+1 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | rwlock01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+558 |
