* | telnet: Use rtems_shell_dup_current_env() | Sebastian Huber | 2020-08-06 | 1 | -1/+1 |
| | | | | Update #3859. | ||||
* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -5/+6 |
* | testsuite: User input define added | Moyano, Gabriel | 2020-03-31 | 1 | -0/+1 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -2/+119 |
* | netshell01: Add license, fix format | Sebastian Huber | 2017-02-28 | 1 | -8/+32 |
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+2 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -0/+1 |
* | Update due to shell API changes | Sebastian Huber | 2014-04-17 | 1 | -1/+2 |
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -1/+0 |
* | netshell01: Avoid multiple definitions | Sebastian Huber | 2013-10-31 | 1 | -5/+0 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -37/+5 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | netshell01: Add netstat command | Joel Sherrill | 2012-10-23 | 1 | -0/+1 |
* | Add ifconfig command as RTEMS Shell command | Joel Sherrill | 2012-10-11 | 1 | -1/+3 |
| | | | | | | | | This is enough to be able to invoke the ifconfig command but it calls exit() which is inappropriate. The "struct option" in the ifconfig code conflicts with a structure of the same name in newlib's and glibc's getopt.h. | ||||
* | netshell01: Add ns parser globals needed for ping. | Jennifer Averett | 2012-10-11 | 2 | -1/+6 |
* | netshell01/.gitignore: Update | Joel Sherrill | 2012-09-11 | 1 | -1/+1 |
* | netshell01/.gitignore: New file | Joel Sherrill | 2012-09-11 | 1 | -0/+1 |
* | freebsd-userspace/Makefile: Resolve conflict so ifconfig and netstat are ↵ | Joel Sherrill | 2012-09-07 | 1 | -1/+1 |
| | | | | both here | ||||
* | netshell01: Link against ping command | Joel Sherrill | 2012-09-07 | 1 | -3/+5 |
* | netshell01: New test and stop using old network configuration code | Joel Sherrill | 2012-09-01 | 3 | -0/+75 |
The old network configuration using a data structure does not support IPV6 and does not support all of the network settings that the FreeBSD command line utilities do. Transition to using the network utilities like ifconfig, route, etc. to initialize the NIC configuration. |
