* | Fix linker errors with minimal build set | Sebastian Huber | 2020-08-06 | 1 | -0/+4 |
* | testsuite: Use new name of test-info.h. | Christian Mauderer | 2020-07-31 | 1 | -1/+1 |
| | | | | | In RTEMS the test.h has been renamed to test-info.h to allow the new test framework to take over. | ||||
* | testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2020-04-03 | 1 | -1/+1 |
* | testsuite: Using RTEMS tester functions at beginning and at the end of tests | Moyano, Gabriel | 2020-03-31 | 1 | -2/+3 |
| | | | | puts() was replaced with rtems_test_begin() and rtems_test_end() | ||||
* | Fix dhcpcd.conf content | Sebastian Huber | 2018-10-11 | 1 | -4/+4 |
| | | | | | Do not write '\0' characters to the file. This confuses the options parser. | ||||
* | Increase file descriptors in default network cfg | Sebastian Huber | 2018-10-10 | 1 | -1/+1 |
| | | | | Make sure we can start the Telnet server in the default configuration. | ||||
* | dhcpcd: Add rtems_dhcpcd_start() | Sebastian Huber | 2018-05-08 | 1 | -32/+5 |
| | | | | Use it throughout to start the DHCP client (dhcpcd). | ||||
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -3/+16 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Add DHCP clientid to test default network init | Sebastian Huber | 2018-04-30 | 1 | -8/+12 |
* | Add wpa_supplicant command in test suite. | Sichen Zhao | 2017-11-10 | 1 | -1/+2 |
| | | | | Add wpa supplicant command in media01. | ||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 1 | -32/+1 |
* | Add CPUINFO command to default network init | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | tests: Remove obsolete config defines | Sebastian Huber | 2017-10-20 | 1 | -2/+0 |
* | Enable bridging by default | Sebastian Huber | 2017-04-04 | 1 | -0/+1 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -1/+2 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -1/+0 |
| | | | | Update #2858. | ||||
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+2 |
* | Enable multi-cast routing support | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Fix default network memory configuration | Sebastian Huber | 2016-11-10 | 1 | -0/+7 |
* | Set syslog priority to 'debug' for all tests. | Chris Johns | 2016-07-06 | 1 | -0/+5 |
* | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 2016-06-30 | 1 | -11/+9 |
| | | | | | The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | ||||
* | Add DEFAULT_NETWORK_PAGE_MBUFS_SIZE to allow per BSP allocation domain sizes. | Chris Johns | 2016-06-27 | 1 | -0/+6 |
* | Update due to RTEMS printer API changes | Sebastian Huber | 2016-06-23 | 1 | -0/+1 |
* | testsuite: Update due to API changes | Sebastian Huber | 2016-05-25 | 1 | -2/+5 |
* | Partially revert 27aedffc1bd8e41f4e06a3326a5b95c54ca38b79 | Sebastian Huber | 2016-05-06 | 1 | -1/+1 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 1 | -1/+2 |
* | default-network-init.h: Fix warnings | Sebastian Huber | 2016-05-04 | 1 | -2/+7 |
* | Add tcpdump to the test shell commands. | Chris Johns | 2016-05-04 | 1 | -1/+2 |
* | testsuite: Add bdbuf configuration | Sebastian Huber | 2015-11-02 | 1 | -0/+4 |
* | tests: Increase stack size for dhcpcd | Sebastian Huber | 2015-09-30 | 1 | -1/+1 |
| | | | | | On i386 with optimization disabled the minimum stack size was not enough. | ||||
* | tests: Support DEFAULT_EARLY_INITIALIZATION | Sebastian Huber | 2015-04-01 | 1 | -0/+4 |
* | LAGG(4): Enable and test | Sebastian Huber | 2015-03-30 | 1 | -0/+1 |
* | VLAN(4): Enable and test | Sebastian Huber | 2015-03-30 | 1 | -0/+1 |
* | tests: Fix define usage | Sebastian Huber | 2015-03-30 | 1 | -4/+4 |
* | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 2015-03-26 | 1 | -0/+1 |
* | tests: Add PROFREPORT shell command | Sebastian Huber | 2015-03-06 | 1 | -0/+1 |
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -0/+1 |
* | testsuite: Fix lo0 ifconfig error | Sebastian Huber | 2014-10-09 | 1 | -0/+1 |
| | | | | Avoid "ifa_del_loopback_route: deletion failed". | ||||
* | testsuite: Add DEFAULT_NETWORK_NO_INTERFACE_0 | Sebastian Huber | 2014-10-08 | 1 | -0/+8 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -0/+2 |
* | Delete rtems_bsd_thread_chain | Sebastian Huber | 2014-09-25 | 1 | -0/+1 |
| | | | | Rely on RTEMS object registration for threads. | ||||
* | DHCPCD(8): Add basic support | Sebastian Huber | 2014-01-30 | 1 | -0/+63 |
* | Add DEFAULT_NETWORK_SHELL | Sebastian Huber | 2014-01-30 | 1 | -0/+55 |
* | Add DEFAULT_NETWORK_NO_STATIC_IFCONFIG | Sebastian Huber | 2014-01-30 | 1 | -9/+34 |
* | Add and use RTEMS_BSD_ARGC() | Sebastian Huber | 2014-01-30 | 1 | -8/+6 |
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -0/+4 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | Fix default network init header | Sebastian Huber | 2013-12-04 | 1 | -2/+3 |
