* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 1 | -10/+3 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 1 | -83/+30 |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | ||||
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 1 | -30/+83 |
* | LOCKING(9): Remove dead code (DDB) | Sebastian Huber | 2017-11-16 | 1 | -3/+0 |
* | LOCKING(9): Remove dead code (KDTRACE_HOOKS) | Sebastian Huber | 2017-11-16 | 1 | -19/+0 |
* | LOCKING(9): Update to current FreeBSD version | Sebastian Huber | 2017-11-16 | 1 | -18/+20 |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 1 | -74/+40 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Rename files for kernel namespace script | Sebastian Huber | 2016-05-06 | 1 | -0/+293 |
This makes it easier to create the kernel namespace header. |
