* | i386: Remove unneeded include header files | Jan Sommer | 2021-06-07 | 2 | -2252/+0 |
* | i386: Delete old machine dependent files | Jan Sommer | 2020-09-16 | 1 | -145/+1 |
| | | | | | | | | - The files in the i386 directory have been moved to common x86 directories by FreeBSD: - freebsd/sys/i386/include/machine/bus.h - freebsd/sys/x86/include/machine/legacyvar.h - freebsd/sys/x86/include/machine/specialreg.h - Add header files in rtemsbsd directory to direct compiler to new files | ||||
* | i386: Port to RTEMS | Jan Sommer | 2020-02-10 | 5 | -0/+2399 |
- Update imported files to compile rtems-libbsd for i386 based BSPs - Currently does not support the option "dev_nic_e1000 = on" |
