* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+1 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 1 | -0/+2 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+1 |
