Update #3277.
Be less dependent on the device tree content.
By default, the network interfaces use a pool channel, see
dpaa_get_channel() in dpaa_eth_priv_probe(). To enable a dedicated QMan
software portal, use libbsd,dedicated-portal = "enabled";. This option
is useful for special purpose 10Gbit/s Ethernet processing.
soc: soc@ffe000000 {
fman0: fman@400000 {
enet7: ethernet@f2000 {
The dequeue support for processor affine QMan portals may be explicitly
disabled. The dequeue support is responsible for receiving frames and
completion of frame transmission, e.g. buffer recycling. Without at
least one enabled dequeue support, there will be no networking.
qman-portals@ff6000000 {
qman-portal@0 {
libbsd,dequeue = "disabled";
Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5).
Imported from Freescale Linux repository
git://git.freescale.com/ppc/upstream/linux.git
commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161.
Linux compatibility layer is partly from FreeBSD.
