- callout_reset_on takes a cpu which is ignored by the subsequent call
to callout_reset_sbt_on in RTEMS.
- The macro is redefined to discard the cpu argument directly which
enables uses of it with cpu-dependent variables (disabled in
RETMS) without further changes, e.g. in iflib.c.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
This flag supports the callout migration in FreeBSD. This feature is
not supported by libbsd.
This flag is only used in combination with the callout expire list,
which we do not use in libbsd.
FreeBSD has two callout executors, one in software and one in hardware
interrupt context. In libbsd, all callouts are executed by the timer
server. Entirely remove the different execution contexts for libbsd.
Previously, this was not properly done which could result an invalid
callout_drain() sequence leading to system memory corruption.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
