* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+12 |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 1 | -0/+1 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 3 | -1/+35 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 4 | -46/+210 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | saf1761_otg: Use real interrupt handler | Sebastian Huber | 2018-10-04 | 3 | -6/+53 |
| | | | | | | | The USB_BUS_SPIN_LOCK() is only used internally to the bus driver. Replace the mutex with an interrupt disable/enable section. Execute the interrupt filter in a real interrupt context and forward the interrupt handler to the interrupt server if necessary. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 9 | -23/+166 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 24 | -101/+260 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 17 | -240/+176 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 14 | -32/+214 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 120 | -122/+310 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 7 | -25/+205 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 3 | -24/+23 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 2 | -2/+1 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | dwc_otg: Default to USB host mode | Sebastian Huber | 2018-02-06 | 1 | -0/+2 |
| | | | | | | In case no "dr_mode" property is present in the device tree, then default to USB host mode. This is necessary to support the Cyclone V SoC Development Kit. | ||||
* | dwc_otg: Add compatibility string, constify | Sebastian Huber | 2018-02-06 | 1 | -1/+2 |
| | | | | Support device tree of Cyclone V SoC Development Kit. | ||||
* | Add device tree support for Altera/Intel Cyclone V | Sebastian Huber | 2018-02-06 | 2 | -0/+266 |
| | | | | Close #3290. | ||||
* | saf1761_otg: Port to RTEMS. | Christian Mauderer | 2017-11-10 | 2 | -4/+84 |
* | usb/saf1761: Import from FreeBSD. | Christian Mauderer | 2017-11-10 | 4 | -0/+4435 |
| | | | | | | | Import the files for the SAF1761 USB controller from FreeBSD commit: 642b174daddbd0efd9bb5f242c43f4ab4db6869f Tue Apr 4 04:01:02 2017 | ||||
* | ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 2017-07-18 | 1 | -0/+5 |
* | Import am335x usb driver file from FreeBSD. | Sichen Zhao | 2017-07-13 | 2 | -0/+4692 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 70 | -70/+70 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 74 | -74/+74 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Modify FREEBSD USB keyboard drivers for use in RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+2 |
* | Add USB UGEN support for RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+10 |
* | Add FREEBSD USB input device files | Kevin Kirspel | 2017-05-19 | 7 | -0/+9186 |
* | Update USB Serial Driver for use with RTEMS | Kevin Kirspel | 2017-05-12 | 1 | -0/+12 |
* | Add USB headers to support USB Serial drivers | Kevin Kirspel | 2017-05-12 | 1 | -0/+99 |
* | Adding FREEBSD USB Serial Drivers | Kevin Kirspel | 2017-05-12 | 23 | -0/+20104 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 10 | -36/+32 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -2/+0 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -0/+3 |
* | Import USB and USB WLAN from FreeBSD. | Christian Mauderer | 2017-01-17 | 52 | -0/+53856 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 2 | -1/+27 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 19 | -135/+273 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | ohci: Fixes due to USB stack update | Sebastian Huber | 2016-10-07 | 1 | -0/+6 |
* | usb: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 19 | -188/+279 |
| | | | | FreeBSD trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 25 | -25/+25 |
* | Fix for directly connected FULL or LOW speed USB devices. | hselasky | 2016-01-05 | 1 | -6/+21 |
| | | | | | Found by: Sebastian Huber <sebastian.huber@embedded-brains.de> MFC after: 1 week | ||||
* | dwc_otg: Import from FreeBSD trunk 2015-11-10 | Sebastian Huber | 2015-11-12 | 3 | -0/+5989 |
* | USB: Update to FreeBSD trunk 2015-11-10 | Sebastian Huber | 2015-11-12 | 46 | -402/+1522 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 20 | -111/+248 |
* | usb: Import USB support from libusb | Sebastian Huber | 2015-05-15 | 2 | -0/+12 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 25 | -260/+1145 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 26 | -349/+621 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 3 | -11/+102 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 24 | -24/+24 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 44 | -1177/+2514 |
* | Use extension to attach a struct thread to threads | Sebastian Huber | 2013-10-10 | 2 | -11/+1 |
| | | | | Add test thread01. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 54 | -901/+901 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 54 | -0/+36813 |
