* | gpioregulator: Remove. | Christian Mauderer | 2020-07-29 | 1 | -352/+0 |
| | | | | | | | | | There is a bug in the #ifdef regarding FDT so this file hasn't been compiled. If that bug is solved, the driver doesn't work for some other reason. With the FDT-bug the driver hasn't been used by anyone. So just remove it again. | ||||
* | regulator: Disable FDT parts for non-FDT targets | Christian Mauderer | 2020-04-17 | 1 | -0/+2 |
* | regulator: Import from FreeBSD. | Christian Mauderer | 2020-04-15 | 1 | -0/+350 |
| | | | | Update #3869. | ||||
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 3 | -29/+174 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 1 | -1/+1 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 2 | -4/+6 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 3 | -0/+6 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Fix build for non-FDT platforms | Sebastian Huber | 2017-11-10 | 1 | -0/+5 |
* | Import BBB sd driver files from FreeBSD. | Sichen Zhao | 2017-11-10 | 3 | -0/+1611 |
