Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a.
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a.
Update #3472.
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
This file seems to be imported from a long gone version.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
