* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -1173/+0 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -14/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -1/+1 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -20/+20 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+1187 |
