* | Pinmux : Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 5 | -0/+978 |
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+21 |
* | freebsd/if_cpsw: Import. | Christian Mauderer | 2018-12-20 | 3 | -0/+3352 |
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -1/+4 |
| | | | | Update #3525. | ||||
* | imx/imx_gpio.c: Import from FreeBSD | Sebastian Huber | 2018-09-25 | 1 | -0/+910 |
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 6 | -2353/+17 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 5 | -10/+37 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 5 | -2503/+0 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 24 | -5/+53 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 4 | -6/+13 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 1 | -1/+32 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | at91_mci: Simplify XDMA usage | Sebastian Huber | 2018-04-27 | 1 | -43/+27 |
* | at91_mci: Get rid of bounce buffer | Sebastian Huber | 2018-04-27 | 1 | -63/+57 |
* | at91_mci: Use real interrupt | Sebastian Huber | 2018-04-26 | 1 | -0/+51 |
| | | | | | Execute at91_mci_intr() in interrupt context. Synchronize MMC requests via RTEMS interrupt lock. | ||||
* | at91_mci: Fix use of BOARD_MCK | Sebastian Huber | 2018-04-26 | 1 | -1/+1 |
* | at91_mci: Fix use of pre-processor defines | Sebastian Huber | 2018-04-26 | 1 | -1/+1 |
* | at91_mci: Fix for 32k buffer. | Christian Mauderer | 2017-11-17 | 1 | -0/+11 |
* | at91_mci: Add timing to read_ivar. | Christian Mauderer | 2017-11-10 | 1 | -0/+10 |
* | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | 2017-11-10 | 2 | -1/+279 |
* | at91_mci: Import from FreeBSD | Sebastian Huber | 2017-11-10 | 5 | -0/+1875 |
* | Import BBB sd driver files from FreeBSD. | Sichen Zhao | 2017-11-10 | 3 | -0/+978 |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 2 | -0/+21 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Import am335x usb driver file from FreeBSD. | Sichen Zhao | 2017-07-13 | 10 | -0/+2473 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 2 | -2/+2 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 4 | -4/+4 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -3/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 2 | -0/+186 |
* | Adding LPC32XX ethernet driver support | Kevin Kirspel | 2017-02-14 | 5 | -0/+2307 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -3/+3 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 2 | -40/+11 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 4 | -270/+471 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Delete superfluous pci_cfgreg.h files | Sebastian Huber | 2015-09-01 | 1 | -60/+0 |
* | Delete superfluous legacyvar.h files | Sebastian Huber | 2015-09-01 | 1 | -63/+0 |
* | Delete superfluous pci_bus.c files | Sebastian Huber | 2015-09-01 | 1 | -736/+0 |
* | Delete superfluous legacy.c files | Sebastian Huber | 2015-09-01 | 1 | -373/+0 |
* | zy7_slcr: Import from FreeBSD | Sebastian Huber | 2015-01-21 | 2 | -0/+741 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 5 | -81/+130 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 2 | -10/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 3 | -3/+3 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 3 | -18/+54 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 6 | -85/+546 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 6 | -0/+1676 |
