Add two underscore characters "__" to names of BIT_* and BITSET_*
macros to move them to the implementation name space and to prevent
a name space pollution due to BIT_* macros in 3rd party programs with
conflicting parameter signatures.
These prefixed macro names are used in kernel header files to define
macros in e.g. sched.h, sys/cpuset.h and sys/domainset.h.
If C programs are built with either -D_KERNEL (automatically passed
when building a kernel or kernel modules) or -D_WANT_FREENBSD_BITSET
(or this macros is defined in the source code before including the
bitset macros), then all macros are made visible with their previous
names, too. E.g., both __BIT_SET() and BIT_SET() are visible with
either of _KERNEL or _WANT_FREEBSD_BITSET defined.
The main reason for this change is that some 3rd party sources
including sched.h have been found to contain conflicting BIT_*
macros.
As a work-around, parts of shed.h have been made conditional and
depend on _WITH_CPU_SET_T being set when sched.h is included.
Ports that expect the full functionality provided by sched.h need
to be built with -D_WITH_CPU_SET_T. But this leads to conflicts if
BIT_* macros are defined in that program, too.
This patch set makes all of sched.h visible again without this
parameter being passed and without any name space pollution due
to BIT_* macros becoming visible when sched.h is included.
This patch set will be backported to the STABLE branches, but ports
will need to use -D_WITH_CPU_SET_T as long as there are supported
releases that do not contain these patches.
Reviewed by: kib, markj
MFC after: 1 month
Relnotes: yes
Differential Revision: https://reviews.freebsd.org/D33235
Update #4654.
This is basically the same as the patch for ping.
Update #4360
- Update imported files to compile rtems-libbsd for i386 based BSPs
- Currently does not support the option "dev_nic_e1000 = on"
Update #3821.
Update #3821.
Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a.
Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418.
It includes an update of wpa_supplicant to version 2.7.
It includes an update of the OpenSSL baseline to version 1.1.1a.
Update #3472.
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a.
Update #3472.
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
Use the FreeBSD 11.1 yacc and lex tools to generate the files.
Update #3472.
This adds two new buildset configurations: One that leaves out as much
features as possible and one that enables all features. For the default
configuration WiFi support is now disabled.
To disable IPv6 for the minimal configuration, all -DINET6 are
eliminated in libbsd.py. They are now replaced by a #ifdef that checks
for RTEMS_BSD_MODULE_NETINET6 instead.
Close #3351.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
FIXME: This reverts the following change in FreeBSD.
commit 76a39ff8dc5e1f7bc8a065115ec3837761ed0600
Author: ae <ae@FreeBSD.org>
Date: Wed Jul 27 08:26:34 2016 +0000
Due to dropped mbuf in netisr queue route(8) can fall into infinity
loop of reading the rtsock's feed. When it used by some scripts,
this leads to growing number of not finished route(8) instances and
thus growing number of rtsock consumers. Add SIGALRM handler to
prevent this.
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab.
Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Prepare update to FreeBSD 11.
Some of the commands have been adapted manually. So the wrapper
currently don't necessarily work as expected. For example ifconfig calls
malloc outside of the program call.
Use SIZE_MAX instead of SIZE_T_MAX to avoid a dependency on BSD
specifics.
This avoids dependencies on a particular generator tool version. On
MinGW and Cygwin hosts these tools tend to be outdated or somehow
incapable.
In the standard RTEMS shell it is not possible to use CTRL-C, to stop
the program. So use a default with finite run-time.
Avoid errors due to optional AF_LOCAL.
