Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Use the FreeBSD 11.1 yacc and lex tools to generate the files.
Update #3472.
Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab.
Use the FreeBSD lex, yacc and rpcgen tools to generate the various
sources used in LibBSD. The change also removes an RTEMS specific change
added when using other hosts operating systems to generate the files.
LibBSD should use FreeBSD version of the tools to generate the source
because the FreeBSD kernel is developed using them.
The change is supported by the waf build which disables generating
the files unless enabled. I am not sure the effect with the Makefile
build support.
This avoids dependencies on a particular generator tool version. On
MinGW and Cygwin hosts these tools tend to be outdated or somehow
incapable.
