* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 1 | -1/+3 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Remove unused inet_* weak references | Sebastian Huber | 2017-06-16 | 1 | -0/+2 |
| | | | | This change requires a Newlib from 2017-06-12 or later. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 1 | -11/+11 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -0/+2 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+416 |
