path: root/dhcpcd/ipv6.h (follow)
* buildset: Add minimal and everything config.Christian Mauderer2018-05-031-0/+3
| | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351.
* DHCPCD(8): ImportSebastian Huber2014-01-301-0/+176
Import DHCPCD(8) from: http://roy.marples.name/projects/dhcpcd/ The upstream sources can be obtained via: fossil clone http://roy.marples.name/projects/dhcpcd The imported version is 2014-01-29 19:46:44 [6b209507bb].
