* | */.../Makefile: MANAGERS=all has been obsolete a LONG time | Joel Sherrill | 2023-04-23 | 4 | -12/+0 |
* | file_io/crc/.gitignore misc/extract_example/.gitignore: New files | Joel Sherrill | 2022-02-23 | 1 | -0/+5 |
* | fdopen: Use rtems_get_version_string() | Sebastian Huber | 2020-09-18 | 1 | -1/+1 |
* | filesystem: Fix file not found error5.35.25.15 | Vijay Kumar Banerjee | 2020-04-26 | 1 | -0/+2 |
* | filesystem: Add checks for rtems-bin2c | Vijay Kumar Banerjee | 2020-03-18 | 1 | -11/+12 |
* | Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with ↵ | Vijay Kumar Banerjee | 2020-03-17 | 5 | -5/+5 |
| | | | | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | ||||
* | update rtems_waf | Vijay Kumar Banerjee | 2019-09-17 | 1 | -3/+3 |
* | file_io/crc/Makefile: Update to match wscript | Joel Sherrill | 2018-10-14 | 1 | -8/+8 |
* | Make crc and fdopen build | Joel Sherrill | 2017-10-12 | 2 | -3/+2 |
| | | | | Updates #3158. | ||||
* | Update due to trace linker changes | Sebastian Huber | 2017-10-12 | 1 | -1/+1 |
| | | | | Close #3160. | ||||
* | Update rtems_waf to use the rootfs support. Fix trace linker INI files. | Chris Johns | 2017-10-02 | 1 | -21/+12 |
| | | | | | | | | | Use the rtems_waf rootfs support to create a root file system. Remove the double cflags on some projects that broke linking. Remove the dump-on-error, there is no option in rtems-tld. Closes 3158. Closes 3159. | ||||
* | Add more trace builds for other examples. | Chris Johns | 2014-09-22 | 2 | -1/+37 |
* | Clean up warnings. | Chris Johns | 2014-09-05 | 1 | -2/+2 |
* | waf: append .exe to target names | Gedare Bloom | 2013-12-12 | 3 | -3/+3 |
* | added wscript to file_io and subdirectories | Daniel Ramirez | 2013-12-12 | 5 | -0/+84 |
* | examples-v2: Remove ChangeLog files | Joel Sherrill | 2013-03-12 | 1 | -40/+0 |
* | examples-v2: Remove .cvsignore files | Joel Sherrill | 2013-03-12 | 4 | -7/+0 |
* | examples-v2 - Remove CVS Ids (manual edits) | Joel Sherrill | 2012-05-15 | 1 | -4/+0 |
* | examples-v2 - Remove CVS Ids (scripted) | Joel Sherrill | 2012-05-15 | 5 | -16/+0 |
* | 2011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-04-01 | 2 | -1/+5 |
| | | | | * Makefile: Update to account for movement of .cfg files. | ||||
* | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-14 | 2 | -0/+6 |
| | | | | * crc/Makefile, fat_ramdisk/Makefile: Fix Makefiles. | ||||
* | 2011-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-11 | 1 | -0/+5 |
| | | | | | * fat_ramdisk/.cvsignore, fat_ramdisk/Makefile, fat_ramdisk/README, fat_ramdisk/init.c, fat_ramdisk/rootfs/shell-init: New files. | ||||
* | 2011-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-11 | 11 | -1/+409 |
| | | | | | | | * Makefile: Add new example of untar to load initial contents of IMFS. * crc/.cvsignore, crc/LICENSE, crc/Makefile, crc/README, crc/crc.h, crc/crc_32.c, crc/init.c, crc/sniptype.h, crc/rootfs/image.img: New files. | ||||
* | 2010-04-12 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-12 | 2 | -0/+5 |
| | | | | * fdopen/test.c: Add include of unistd.h for close(). | ||||
* | 2010-04-09 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-09 | 2 | -0/+6 |
| | | | | * filerdback/test.c: Add CVS Id. | ||||
* | 2010-04-09 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-09 | 2 | -0/+5 |
| | | | | * filerdback/test.c: Add include of unistd.h | ||||
* | 2009-08-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-06 | 14 | -0/+534 |
* ChangeLog, Makefile, fdopen/.cvsignore, fdopen/Makefile, fdopen/README, fdopen/test.c, filerdback/.cvsignore, filerdback/Makefile, filerdback/README, filerdback/test.c, repeated_opens/.cvsignore, repeated_opens/Makefile, repeated_opens/README, repeated_opens/test.c: New files. |
