* | Add regulator exampleHEADmaster | Joel Sherrill | 2023-07-29 | 6 | -0/+308 |
| | | | | Updates #4924. | ||||
* | */.../Makefile: MANAGERS=all has been obsolete a LONG time | Joel Sherrill | 2023-04-23 | 46 | -139/+1 |
* | livermore/wscript: POSIX threads does not require POSIX enabled | Joel Sherrill | 2023-04-23 | 1 | -2/+1 |
* | psx_sched_report/psx_sched_report.c: Do not assume pid=1 | Joel Sherrill | 2023-04-23 | 1 | -1/+1 |
* | led/wscript: POSIX threads does not require POSIX enabled | Joel Sherrill | 2023-04-23 | 1 | -9/+8 |
* | hello/wscript: POSIX threads does not require POSIX enabled | Joel Sherrill | 2023-04-23 | 1 | -3/+2 |
* | c11/wscript: C11 concurrency does not require POSIX enabled | Joel Sherrill | 2023-04-23 | 1 | -5/+4 |
* | waf: Update to waf 2..0.25 | Joel Sherrill | 2023-02-17 | 1 | -8/+8 |
| | | | | Updates #4860 | ||||
* | hello_world_c: Fix test output | Ryan Long | 2022-03-03 | 1 | -1/+0 |
| | | | | | Removed the CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM to make it produce the correct output. | ||||
* | file_io/crc/.gitignore misc/extract_example/.gitignore: New files | Joel Sherrill | 2022-02-23 | 2 | -0/+6 |
* | ticker/low_ticker2: Fix warnings | Joel Sherrill | 2022-02-23 | 1 | -9/+10 |
* | ticker/low_ticker1: Fix warnings | Joel Sherrill | 2022-02-23 | 1 | -10/+11 |
* | ticker/low_ticker: Fix warnings | Joel Sherrill | 2022-02-23 | 1 | -9/+10 |
* | misc/nanosecond_tick_wrap: Fix warnings | Joel Sherrill | 2022-02-23 | 1 | -2/+2 |
* | misc/minimum/: Fix warnings | Joel Sherrill | 2022-02-23 | 3 | -21/+21 |
* | classic_api/classic_signal: Fix warnings | Joel Sherrill | 2022-02-23 | 1 | -3/+1 |
* | benchmarks/nbench: Fix warnings | Joel Sherrill | 2022-02-23 | 5 | -4/+14 |
* | posix_api/Makefile ticker/Makefile: Add missing examples | Joel Sherrill | 2022-02-23 | 2 | -1/+8 |
* | tracing: Add a special ticker variant to show tracing. | Joel Sherrill | 2022-02-23 | 7 | -16/+162 |
| | | | | | This was complicating both_hello which was designed for another purpose entirely. | ||||
* | ticker_stackhk: Add variant which prints stack and cpu usage reports | Joel Sherrill | 2022-02-23 | 4 | -1/+149 |
* | Add POSIX task and thread restart examples. | Joel Sherrill | 2022-02-23 | 9 | -0/+283 |
| | | | | A POSIX thread must be detached to be able to restart it. | ||||
* | Add User Driver Example | Joel Sherrill | 2022-02-23 | 10 | -1/+3042 |
* | led/event_server/init.c: Use names for events to reflect application intent | Joel Sherrill | 2022-02-23 | 1 | -6/+10 |
* | led/delay/init.c: Use local variable for one second of ticks | Joel Sherrill | 2022-02-23 | 1 | -4/+6 |
* | posix_api/psx_example_3/test3.c: Clean up and allow to build on Linux | Joel Sherrill | 2022-02-23 | 1 | -13/+32 |
* | classic_api/triple_period/tasks.c: Clean up formatting | Joel Sherrill | 2022-02-23 | 1 | -3/+4 |
* | cxx_throw/wscript: Fix comment | Joel Sherrill | 2022-02-23 | 1 | -1/+1 |
* | cxx_stdmap: Add example of using std::map with RTEMS | Joel Sherrill | 2022-02-23 | 6 | -1/+141 |
* | psx_sched_report/rtems_config.c: Fix spacing | Joel Sherrill | 2022-02-23 | 1 | -0/+1 |
* | psx_initial_sigmask: Add POSIX initial signal mask reporter | Joel Sherrill | 2021-08-20 | 4 | -0/+208 |
* | psx_sigint: Add new example of POSIX signal and default mask | Joel Sherrill | 2021-08-20 | 6 | -0/+184 |
* | Conditionalize CONFIGURE_TERMIOS_DISABLE so the examples span versions | Joel Sherrill | 2021-08-20 | 3 | -0/+26 |
* | lvgl/wscript: Add libpath to search for required libraries | Vijay Kumar Banerjee | 2021-03-29 | 1 | -2/+10 |
* | fdopen: Use rtems_get_version_string() | Sebastian Huber | 2020-09-18 | 1 | -1/+1 |
* | psx_example_2: Fix warning | Sebastian Huber | 2020-09-18 | 1 | -1/+1 |
* | wscript: Update RTEMS version to 6 | Sebastian Huber | 2020-09-18 | 1 | -1/+1 |
| | | | | Update #4020. | ||||
* | lvgl: Add a gui example with evdev | Vijay Kumar Banerjee | 2020-06-14 | 5 | -6/+723 |
| | | | | This example uses the evdev interface to add mouse input to interact with the GUI | ||||
* | filesystem: Fix file not found error5.35.25.15 | Vijay Kumar Banerjee | 2020-04-26 | 2 | -0/+4 |
* | filesystem: Add checks for rtems-bin2c | Vijay Kumar Banerjee | 2020-03-18 | 2 | -20/+21 |
* | Update rtems_waf | Vijay Kumar Banerjee | 2020-03-18 | 1 | -0/+0 |
* | Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with ↵ | Vijay Kumar Banerjee | 2020-03-17 | 20 | -20/+20 |
| | | | | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | ||||
* | waf: Update to waf-2.0.19 | Sebastian Huber | 2020-02-27 | 1 | -9/+12 |
| | | | | Update #3569. | ||||
* | Add lvgl/hello: Sample Hello world app using littleVGL and libbsd | Vijay Kumar Banerjee | 2019-09-20 | 7 | -2/+214 |
* | update rtems_waf | Vijay Kumar Banerjee | 2019-09-17 | 3 | -6/+6 |
* | Fix warnings | Sebastian Huber | 2019-01-07 | 2 | -2/+2 |
| | | | | Close #3670. | ||||
* | Update due to block device API changes | Sebastian Huber | 2019-01-07 | 2 | -47/+6 |
| | | | | | Update #3358. Update #3670. | ||||
* | Fix typo in configuration | Sebastian Huber | 2019-01-07 | 1 | -1/+1 |
* | Remove obsolete Termios configuration | Sebastian Huber | 2019-01-07 | 5 | -11/+0 |
* | Remove obsolete CONFIGURE_MAXIMUM_PTYS | Sebastian Huber | 2019-01-07 | 1 | -1/+0 |
* | Ignore the waf python3 workspace. | Chris Johns | 2018-12-26 | 1 | -1/+1 |
