* | user: Remove obsolete content in quick start | Sebastian Huber | 2019-02-18 | 1 | -87/+0 |
* | user: Add "Build Your Application" | Sebastian Huber | 2019-02-18 | 2 | -0/+12 |
* | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 3 | -0/+69 |
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 2 | -0/+147 |
* | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2019-02-18 | 2 | -0/+56 |
* | user: Add "Install the Tool Suite" section | Sebastian Huber | 2019-02-18 | 3 | -0/+130 |
* | user: Add "Obtain the Sources" section | Sebastian Huber | 2019-02-18 | 2 | -0/+52 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 5 | -41/+41 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Fix references to prefixes section | Sebastian Huber | 2019-02-18 | 5 | -9/+7 |
* | user: Rework "Host Computer Setup" section | Sebastian Huber | 2019-02-18 | 2 | -10/+14 |
| | | | | Rename it to "Prepare Your Host Computer". | ||||
* | user: Add product name | Sebastian Huber | 2019-02-18 | 1 | -2/+2 |
* | user: Add basic Intel Cyclone V documentation | Sebastian Huber | 2019-02-18 | 1 | -2/+73 |
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | user: Add basic event recording documentation | Sebastian Huber | 2019-02-01 | 5 | -4/+64 |
| | | | | Update #3665. | ||||
* | user: Use capital letters for acronyms | Sebastian Huber | 2019-01-24 | 2 | -4/+5 |
| | | | | Fix GCC definition. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 11 | -21/+21 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+20 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 4 | -42/+57 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 8 | -104/+120 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | user: Move deployment details to RSB chapter | Sebastian Huber | 2019-01-14 | 3 | -155/+164 |
* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -242/+239 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -128/+125 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+12 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 10 | -15/+2772 |
| | | | | Remove the separate RSB manual. | ||||
* | user: Remove unused file | Sebastian Huber | 2019-01-11 | 1 | -10/+0 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 66 | -66/+66 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 42 | -42/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 61 | -62/+81 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 3 | -31/+233 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 2 | -4/+4 |
* | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 2018-11-16 | 1 | -3/+13 |
| | | | | Closes #3416. | ||||
* | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | 2018-11-16 | 1 | -2/+2 |
* | user: add a warning not to use special characters in pathnames | Marçal Comajoan Cara | 2018-11-16 | 1 | -0/+7 |
| | | | | | | | | | | | | | | | Spaces and other specical characters in pathnames break builds of any software packages using GNU make. All of the GNU tools and RTEMS use make and this breaks builds. This is a long standing known issue with GNU make, which can't handle spaces in pathnames: https://savannah.gnu.org/bugs/?712 This work was part of GCI 2018. Probably closes #3450. | ||||
* | Remove m32c architecture port | Sebastian Huber | 2018-11-09 | 1 | -2/+1 |
| | | | | Update #3599. | ||||
* | user: spelling and grammar fixes | Marçal Comajoan Cara | 2018-11-09 | 2 | -5/+5 |
| | | | | This work was part of GCI 2018. | ||||
* | user: Update architecture list | Sebastian Huber | 2018-11-08 | 1 | -1/+3 |
* | user: Remove obsolete boostrap -p step | Sebastian Huber | 2018-11-08 | 1 | -44/+2 |
| | | | | Update #3254. | ||||
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 17 | -47/+1371 |
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 4 | -10/+26 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 4 | -236/+383 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 4 | -18/+240 |
* | user: Document QorIQ BSP variants | Sebastian Huber | 2018-10-01 | 1 | -0/+3 |
* | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 2018-09-25 | 1 | -0/+8 |
| | | | | Close #3525. | ||||
* | user: Add qoriq BSP section | Sebastian Huber | 2018-08-29 | 1 | -1/+78 |
| | | | | Update #2854. |
