* | Add a Hardware section. | Chris Johns | 2016-07-06 | 9 | -19/+224 | |
* | Update the glossary. | Chris Johns | 2016-07-06 | 1 | -0/+25 | |
* | Add the RTEMS Kernel section back in. | Chris Johns | 2016-07-04 | 3 | -0/+435 | |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 19 | -843/+734 | |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 28 | -0/+56 | |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 2 | -1/+1 | |
* | Review changes from Chris Mayfield. | Chris Johns | 2016-05-02 | 3 | -61/+67 | |
* | Corrections from Worth Burruss. Many thanks. | Chris Johns | 2016-05-02 | 2 | -8/+7 | |
* | Corrections from Worth Burruss. Many thanks. | Chris Johns | 2016-05-02 | 9 | -79/+143 | |
* | Fix bad formatting that somehow went into the doco. | Chris Johns | 2016-05-02 | 1 | -47/+47 | |
* | Corrections from a review. | Chris Johns | 2016-05-02 | 3 | -87/+97 | |
* | Corrections and improvements from Worth Burruss (thanks so much). | Chris Johns | 2016-05-02 | 2 | -7/+38 | |
* | Corrections. | Chris Johns | 2016-05-02 | 3 | -39/+65 | |
* | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 2016-05-02 | 8 | -380/+563 | |
* | Start adding Getting Started guide's Released Version. | Chris Johns | 2016-05-02 | 1 | -2/+267 | |
* | Updates from user reviews. | Chris Johns | 2016-05-02 | 2 | -23/+28 | |
* | Split installation into separate files. | Chris Johns | 2016-05-02 | 6 | -632/+646 | |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 17 | -56/+1612 | |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 | |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 | |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 | |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 | |
| | | | | Needed to switch due to increasing complexity. | |||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 25 | -0/+432 | |
