path: root/user (follow)
* Clean up sphinx warnings.Chris Johns2017-11-136-83/+43
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-1317-228/+30
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Change RTEMS version to 5Sebastian Huber2017-11-099-228/+244
| | | | Update #3220.
* Update copyright notices.Chris Johns2017-08-113-11/+32
* User Manual: Added rtems-tester in the docsTanu Hari Dixit2017-06-142-0/+447
| | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected.
* User: Remove conflict marker.Chris Johns2017-06-011-1/+0
* User: Remove the stash conflict markers.Chris Johns2017-05-311-4/+0
* User: Improvements to some of the tools commands.Chris Johns2017-05-313-50/+51
* User Manual: Update the rtems-bsp-builder command.Chris Johns2017-05-241-420/+282
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-6/+7
* user: Fix typo.Chris Johns2017-03-211-1/+1
* user: Minor fixes to rtems-bsp-builder.Chris Johns2017-03-211-3/+3
* user: Add an example of the rtems-bsp-builder running.Chris Johns2017-03-211-2/+389
* Use a single top level version number.Chris Johns2017-03-201-4/+5
* user: Add tool commands to the user manual.Chris Johns2017-03-157-23/+612
* Update document titles for consistencyJoel Sherrill2017-01-111-3/+3
* Remove references to SPARC/SIS BSP. Also clean up old ERC32 references.Joel Sherrill2017-01-111-1/+1
| | | | updates #2810.
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* user: Fix header levels.Chris Johns2016-11-0928-65/+88
* Fix spelling.Chris Johns2016-11-021-1/+1
* waf: Add an install command.Chris Johns2016-10-311-2/+6
* waf: Formatting.Chris Johns2016-10-301-2/+2
* user: Add comments about warnings we cannot remove.Chris Johns2016-10-292-0/+5
* user: Add comment to move to packages.Chris Johns2016-10-291-0/+3
* ecosys/index.rst: Fix complixity spellingJoel Sherrill2016-10-271-1/+1
* Fix the table and section numbering in the User,Hardware,Tiers section.Chris Johns2016-07-061-16/+16
* Add a Hardware section.Chris Johns2016-07-069-19/+224
* Update the glossary.Chris Johns2016-07-061-0/+25
* Add the RTEMS Kernel section back in.Chris Johns2016-07-043-0/+435
* Reorganisse the User Manual to make it easier to navigate.Chris Johns2016-07-0419-843/+734
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2028-0/+56
* Move images to a common directory.Amar Takhar2016-05-182-1/+1
* Review changes from Chris Mayfield.Chris Johns2016-05-023-61/+67
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-022-8/+7
* Corrections from Worth Burruss. Many thanks.Chris Johns2016-05-029-79/+143
* Fix bad formatting that somehow went into the doco.Chris Johns2016-05-021-47/+47
* Corrections from a review.Chris Johns2016-05-023-87/+97
* Corrections and improvements from Worth Burruss (thanks so much).Chris Johns2016-05-022-7/+38
* Corrections.Chris Johns2016-05-023-39/+65
* Add a basics section to Getting Started. Rearrange the content.Chris Johns2016-05-028-380/+563
* Start adding Getting Started guide's Released Version.Chris Johns2016-05-021-2/+267
* Updates from user reviews.Chris Johns2016-05-022-23/+28
* Split installation into separate files.Chris Johns2016-05-026-632/+646
* User manual, devel install and windows install.Chris Johns2016-05-0217-56/+1612
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Rework how conf.py is handled.Amar Takhar2016-05-022-9/+9
| | | | Needed to switch due to increasing complexity.
* Initial reST documentation using Sphinx.Amar Takhar2016-05-0225-0/+432
