* | c-user: Remove obsolete config section | Sebastian Huber | 2023-02-14 | 1 | -1/+0 |
| | | | | | | | | | | | | This commit already clarified that the defines of the removed section are optional BSP provided default values and not application configuration options: commit cf9f2121577b11f8eab5e49c48173c46cf09c627 Author: Sebastian Huber <sebastian.huber@embedded-brains.de> Date: Wed Nov 17 08:46:56 2021 +0100 c-user: Clarify BSP related configuration settings | ||||
* | c-user: Add application config info directives | Sebastian Huber | 2022-10-04 | 1 | -0/+2 |
| | | | | | Close #4267. Close #4269. | ||||
* | c-user/config/face.rst: New file -- add CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR | Joel Sherrill | 2022-09-05 | 1 | -0/+1 |
| | | | | Closes #4691. | ||||
* | c-user: Reorder configuration option groups | Sebastian Huber | 2020-03-13 | 1 | -4/+4 |
| | | | | | | | Sort the configuration option groups according to the likelihood a user will define options of a group. Update #3836. | ||||
* | c-user: Clarify message buffer configuration | Sebastian Huber | 2020-03-13 | 1 | -1/+0 |
| | | | | | | | | | The help macro CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE() is not a configuration option. Move it into the documentatation of the CONFIGURE_MESSAGE_BUFFER_MEMORY configuration option. Move this option to the general system configuration group. Update #3836. | ||||
* | c-user: Move "Obsolete Configuration Options" | Sebastian Huber | 2020-03-12 | 1 | -221/+1 |
* | c-user: Move "Ada Configuration" | Sebastian Huber | 2020-03-12 | 1 | -12/+1 |
* | c-user: Move "Event Recording Configuration" | Sebastian Huber | 2020-03-12 | 1 | -58/+1 |
* | c-user: Move "PCI Library Configuration" | Sebastian Huber | 2020-03-12 | 1 | -52/+1 |
* | c-user: Move "Multiprocessing Configuration" | Sebastian Huber | 2020-03-12 | 1 | -181/+1 |
* | c-user: Move "Device Driver Configuration" | Sebastian Huber | 2020-03-12 | 1 | -504/+1 |
* | c-user: Move "Clustered Scheduler Configuration" | Sebastian Huber | 2020-03-12 | 1 | -216/+1 |
* | c-user: Move "General Scheduler Configuration" | Sebastian Huber | 2020-03-12 | 1 | -386/+1 |
* | c-user: Move "Idle Task Configuration" | Sebastian Huber | 2020-03-12 | 1 | -93/+1 |
* | c-user: Move "BSP Related Configuration Options" | Sebastian Huber | 2020-03-12 | 1 | -244/+1 |
* | c-user: Move "Block Device Cache Configuration" | Sebastian Huber | 2020-03-12 | 1 | -335/+1 |
* | c-user: Move "Filesystem Configuration" | Sebastian Huber | 2020-03-12 | 1 | -544/+1 |
* | c-user: Move "Message Queue Buffer Configuration" | Sebastian Huber | 2020-03-12 | 1 | -90/+1 |
* | c-user: Move "Task Stack Allocator Configuration" | Sebastian Huber | 2020-03-12 | 1 | -110/+1 |
* | c-user: Move "POSIX Initialization Thread Configuration" | Sebastian Huber | 2020-03-12 | 1 | -102/+1 |
* | c-user: Move "POSIX API Configuration" | Sebastian Huber | 2020-03-12 | 1 | -249/+1 |
* | c-user: Move "Classic API Initialization Task Configuration" | Sebastian Huber | 2020-03-12 | 1 | -231/+1 |
* | c-user: Move "Classic API Configuration" | Sebastian Huber | 2020-03-12 | 1 | -288/+1 |
* | c-user: Move "General System Configuration" | Sebastian Huber | 2020-03-12 | 1 | -636/+1 |
* | c-user: Split up configuring_a_system.rst | Sebastian Huber | 2020-03-11 | 1 | -0/+4565 |
Introduce an index file for this chapter. This helps to generate some sections from the specification in the future. Start with moving "Introduction" up to "Unlimited Objects" to a new file. Update #3836. |
