* | c-user: Clarify CONFIGURE_TICKS_PER_TIMESLICE | Sebastian Huber | 2024-03-20 | 1 | -1/+1 |
| | | | | Close #4986. | ||||
* | c-user: CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY | Sebastian Huber | 2023-12-19 | 1 | -1/+36 |
| | | | | | | Document CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY. Update #4961. | ||||
* | c-user: Link task entry and global construction | Sebastian Huber | 2023-07-25 | 3 | -3/+12 |
* | Update company name | Sebastian Huber | 2023-05-20 | 15 | -15/+15 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | c-user: Generate API type documentation | Sebastian Huber | 2023-05-09 | 3 | -4/+4 |
| | | | | Close #4901. | ||||
* | c-user: Use configuration option references | Sebastian Huber | 2023-02-14 | 1 | -31/+32 |
* | c-user: Document CONFIGURE_INIT | Sebastian Huber | 2023-02-14 | 2 | -2/+38 |
* | c-user: Fix header file path | Sebastian Huber | 2023-02-14 | 1 | -2/+3 |
* | c-user: Harmonize header file references | Sebastian Huber | 2023-02-14 | 2 | -7/+7 |
* | c-user: Remove obsolete config section | Sebastian Huber | 2023-02-14 | 2 | -356/+0 |
| | | | | | | | | | | | | This commit already clarified that the defines of the removed section are optional BSP provided default values and not application configuration options: commit cf9f2121577b11f8eab5e49c48173c46cf09c627 Author: Sebastian Huber <sebastian.huber@embedded-brains.de> Date: Wed Nov 17 08:46:56 2021 +0100 c-user: Clarify BSP related configuration settings | ||||
* | Document CONFIGURE_RECORD_INTERRUPTS_ENABLED | Sebastian Huber | 2022-12-02 | 1 | -1/+42 |
| | | | | Close #4769. | ||||
* | c-user: Add CONFIGURE_IDLE_TASK_STORAGE_SIZE | Sebastian Huber | 2022-10-14 | 2 | -11/+101 |
* | c-user: Fix references | Sebastian Huber | 2022-10-06 | 1 | -10/+5 |
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2022-10-06 | 2 | -63/+63 |
| | | | | | Move CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE to the general configuration options. | ||||
* | c-user: Add application config info directives | Sebastian Huber | 2022-10-04 | 10 | -90/+1826 |
| | | | | | Close #4267. Close #4269. | ||||
* | c-user/config/face.rst: New file -- add CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR | Joel Sherrill | 2022-09-05 | 2 | -0/+77 |
| | | | | Closes #4691. | ||||
* | c-user: Clarify BSP related configuration settings | Sebastian Huber | 2022-08-31 | 3 | -9/+76 |
* | c-user: Update OAR copyright and reformat | Sebastian Huber | 2022-08-11 | 3 | -14/+10 |
| | | | | These files are generated by a script. | ||||
* | c-user: Update references to --enable-* configure options. | Joel Sherrill | 2022-05-20 | 3 | -23/+28 |
| | | | | | Also updated list of SMP architectures and added enough lead in to let users know the source code was the definitive answer. | ||||
* | c-user: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES | Sebastian Huber | 2022-02-22 | 1 | -3/+90 |
| | | | | Update #4524. | ||||
* | c-user: Use rubric for configuration options | Sebastian Huber | 2021-11-17 | 14 | -3029/+4307 |
| | | | | | | | | | | | | | Clear the page for each configuration options similar to the directives. Use a rubric instead of a definition list for the application configuration options similar to the directive documentation pages. For direcives and application configuration options use the same rubric order. Generalize value constraints to constraints. This patch does not change hand written content. | ||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 2021-11-16 | 1 | -2/+2 |
| | | | | Fix default value description. | ||||
* | c-user: Update for application CONFIGURE option | Kinsey Moore | 2021-11-03 | 1 | -0/+30 |
| | | | | | This adds the documentation for the application configuration option CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING. | ||||
* | c-user: Regenerate for IDLE task allocator option | Sebastian Huber | 2021-10-25 | 1 | -34/+37 |
* | task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR | Joel Sherrill | 2021-10-12 | 1 | -0/+33 |
| | | | | Updates #4524. | ||||
* | c-user: Change format of external function refs | Sebastian Huber | 2021-05-08 | 1 | -1/+1 |
* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 14 | -330/+414 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | c-user: CONFIGURE_BSP_PREREQUISITE_DRIVERS | Sebastian Huber | 2021-04-29 | 1 | -2/+2 |
| | | | | Replace copy and paste with a proper description. | ||||
* | c-user: Add missing "the" | Sebastian Huber | 2021-04-29 | 1 | -11/+10 |
* | c-user: Clarify constraints | Sebastian Huber | 2021-03-08 | 1 | -2/+8 |
* | c-user: Add labels to the manager chapters | Sebastian Huber | 2021-02-10 | 1 | -1/+1 |
| | | | | Update #3993. | ||||
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 14 | -42/+98 |
* | c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 2020-11-25 | 1 | -1/+68 |
| | | | | | | | Document new configuration option CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE. Close #4181. | ||||
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 14 | -70/+56 |
* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 14 | -0/+330 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 14 | -56/+126 |
* | c-user: Fix use of getchark() and rtems_putc() | Sebastian Huber | 2020-09-28 | 1 | -4/+4 |
* | c-user: CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE | Sebastian Huber | 2020-09-17 | 1 | -0/+32 |
| | | | | | | Document this application configuration option. Update #3959. | ||||
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 1 | -0/+44 |
| | | | | | | Document this application configuration option. Close #4074. | ||||
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 14 | -0/+98 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 14 | -98/+136 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM | Sebastian Huber | 2020-08-07 | 1 | -2/+2 |
| | | | | Improve formatting. | ||||
* | c-user: Unify references in appl config chapter | Sebastian Huber | 2020-07-23 | 4 | -62/+49 |
| | | | | | This is a prepration step to allow the generation of the application configuration options in Doxygen markup. | ||||
* | c-user: Fix CONFIGURE_MAXIMUM_PROCESSORS minimum | Sebastian Huber | 2020-07-07 | 1 | -1/+1 |
* | c-user: Fix appl config option references | Sebastian Huber | 2020-07-06 | 2 | -2/+2 |
* | c-user: Sort appl config options by name | Sebastian Huber | 2020-07-06 | 3 | -72/+72 |
* | c-user: Use * for list items | Sebastian Huber | 2020-06-17 | 4 | -51/+51 |
* | c-user: Fix RTEMS_SCHEDULER_EDF_SMP() | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3815. | ||||
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 1 | -44/+0 |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | ||||
* | c-user: Move CONFIGURE_MAXIMUM_PRIORITY | Sebastian Huber | 2020-04-02 | 2 | -58/+58 |
| | | | | | | Move this option to the scheduler configuration options. Update #3836. |
