* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | c-user: Use rubric for configuration options | Sebastian Huber | 2021-11-17 | 1 | -216/+293 |
| | | | | | | | | | | | | | Clear the page for each configuration options similar to the directives. Use a rubric instead of a definition list for the application configuration options similar to the directive documentation pages. For direcives and application configuration options use the same rubric order. Generalize value constraints to constraints. This patch does not change hand written content. | ||||
* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 1 | -27/+67 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 1 | -3/+7 |
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 1 | -5/+4 |
* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 1 | -0/+28 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 1 | -4/+9 |
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 1 | -0/+7 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 1 | -9/+9 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: Sort appl config options by name | Sebastian Huber | 2020-07-06 | 1 | -19/+19 |
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 1 | -78/+114 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-24 | 1 | -11/+10 |
| | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Close #3900. | ||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 1 | -2/+2 |
| | | | | Update #3836. | ||||
* | c-user: Sort configuration options alphabetically | Sebastian Huber | 2020-03-17 | 1 | -24/+24 |
* | c-user: Move "Block Device Cache Configuration" | Sebastian Huber | 2020-03-12 | 1 | -0/+338 |
Update #3836. |
