* | c-user: Add "Kernel Character I/O Support" chapter | Sebastian Huber | 2021-08-03 | 7 | -8/+465 |
| | | | | Close #4482. | ||||
* | eng: Add freestanding test cases | Sebastian Huber | 2021-08-03 | 1 | -0/+6 |
| | | | | Update #3715. | ||||
* | user/imxrt: Add notes about problems with EVB | Christian Mauderer | 2021-07-29 | 1 | -0/+9 |
| | | | | | There are some possible problems with the i.MXRT1050 evaluation board. Make some notes about that in the BSP manual. | ||||
* | c-user: Remove _Internal_errors_What_happened | Sebastian Huber | 2021-07-28 | 1 | -3/+2 |
| | | | | This global object no longer exists. | ||||
* | c-user: Document interrupt manager extensions | Sebastian Huber | 2021-07-27 | 2 | -72/+2714 |
| | | | | Close #3269. | ||||
* | README: Added centOS 8 instructions | Stephen Clark | 2021-07-20 | 1 | -0/+11 |
| | | | | Added some instructions for setting up CentOS 8. | ||||
* | README: Minor clarifications and fixes | Stephen Clark | 2021-07-20 | 1 | -24/+25 |
| | | | | | | Fixed some minor typographical errors. Updated a dead link. Reworded some sentences for clarity. | ||||
* | user/bsps/aarch64: Minor formatting fix | Stephen Clark | 2021-07-15 | 2 | -6/+10 |
| | | | | | Fixed formatting error in user/bsps/aarch64/a53.rst and user/bsps/aarch64/xilinx-zynqmp.rst. | ||||
* | xilinx-zynqmp.rst: Documented SDIO driver | Stephen Clark | 2021-07-15 | 1 | -0/+14 |
| | | | | Added documentation for SDIO driver. | ||||
* | user: Update ZynqMP network configuration | Kinsey Moore | 2021-07-15 | 1 | -8/+3 |
| | | | | | Network configuration is now automatic and requires no user configuration. | ||||
* | rtems-docs: remove Eclipse Manual | Ray Garza | 2021-07-06 | 35 | -479/+0 |
| | | | | | Due to RTEMS 6 no longer using the Make build system and instead using Waf (Eclipse does not offer Waf support), this guide is being removed. | ||||
* | user/bsps/imxrt: Info about ARM PLL frequency | Christian Mauderer | 2021-07-02 | 1 | -0/+20 |
| | | | | Update #4180 | ||||
* | user/bsps/imxrt: Fix typo | Christian Mauderer | 2021-07-02 | 1 | -1/+1 |
* | user/bsps: Update ZynqMP for hardware BSPs | Kinsey Moore | 2021-07-01 | 1 | -8/+49 |
| | | | | | | Update the ZynqMP documentation for the new hardware BSP variants including information about booting, boot image generation, and networking. | ||||
* | user/bsps: add aarch64 xilinx-versal | Gedare Bloom | 2021-06-22 | 2 | -0/+40 |
* | user: Fixed typo to build hello application | Ida Delphine | 2021-06-15 | 1 | -1/+1 |
* | c-user: Use a common phrase for pointer parameters | Sebastian Huber | 2021-06-15 | 15 | -159/+163 |
| | | | | | | | Mention the type of the pointer in the parameter description. Use the more general term "object" instead of "variable". Update #3993. | ||||
* | user: add bsps/aarch64/a72.rst | Gedare Bloom | 2021-06-08 | 2 | -0/+36 |
* | user: fix typo in aarch64/a53.rst | Gedare Bloom | 2021-06-08 | 1 | -1/+1 |
* | Update Compliance Tracking CSV file to fix minor bugs | Joel Sherrill | 2021-06-04 | 2 | -873/+874 |
* | eng/vc-authors: Add section on migrating personal repo to top-level | Vijay Kumar Banerjee | 2021-05-30 | 1 | -0/+46 |
* | c-users: Add rtems_*mutex_try_lock | Christian Mauderer | 2021-05-28 | 1 | -0/+35 |
| | | | | Closes #4440. | ||||
* | bsps/imxrt: Remove superfluous options from dtc | Christian Mauderer | 2021-05-28 | 1 | -1/+1 |
| | | | | | | | | | | | The -@ option adds symbols that are used when applying an overlay. RTEMS doesn't support overlays or re-parsing of device trees. So the symbols only increase the size of the binary. The same is true for the padding. It would be useful if the device tree is changed during run time which is not supported in RTEMS. Update #4180 | ||||
* | c-user: Document new rtems_task_delete() error | Sebastian Huber | 2021-05-27 | 1 | -0/+3 |
| | | | | Close #4414. | ||||
* | Fix the bibtex extension configure test | Chris Johns | 2021-05-21 | 1 | -2/+4 |
* | Fix the linux specific include | Chris Johns | 2021-05-21 | 1 | -4/+4 |
* | posix-compliance: Update to include POSIX 1003.1-2017 (Issue 7). | Joel Sherrill | 2021-05-17 | 4 | -1379/+1395 |
* | posix-compliance/posix_rst.py: Use proper names of standards in headings | Joel Sherrill | 2021-05-17 | 1 | -18/+18 |
* | user/bld/index.rst: removed references to legacy network config options | Harrison Edward Gerber | 2021-05-16 | 1 | -7/+0 |
* | c-user: Constify rtems_task_wake_when() | Sebastian Huber | 2021-05-12 | 1 | -1/+1 |
| | | | | Update #4406. | ||||
* | c-user: Clarify rtems_task_get_priority() | Sebastian Huber | 2021-05-12 | 1 | -2/+2 |
* | c-user: Document rtems_task_set_scheduler() errors | Sebastian Huber | 2021-05-12 | 1 | -2/+22 |
* | c-user: Add task priority glossary terms | Sebastian Huber | 2021-05-12 | 1 | -3/+38 |
* | c-user: Change format of external function refs | Sebastian Huber | 2021-05-08 | 1 | -1/+1 |
* | eng: Add unspecified interface groups | Sebastian Huber | 2021-05-08 | 1 | -0/+3 |
* | c-user: rtems_scheduler_get_processor_set() | Sebastian Huber | 2021-05-07 | 1 | -1/+1 |
| | | | | | | Document changed error status. Update #4401. | ||||
* | c-user: rtems_scheduler_ident_by_processor_set() | Sebastian Huber | 2021-05-07 | 1 | -0/+4 |
| | | | | Document new error status. | ||||
* | eng: Remove text attribute from acfg options | Sebastian Huber | 2021-04-30 | 1 | -6/+0 |
* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 14 | -330/+414 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | c-user: CONFIGURE_BSP_PREREQUISITE_DRIVERS | Sebastian Huber | 2021-04-29 | 1 | -2/+2 |
| | | | | Replace copy and paste with a proper description. | ||||
* | c-user: Add missing "the" | Sebastian Huber | 2021-04-29 | 1 | -11/+10 |
* | eng: Add test suite name | Sebastian Huber | 2021-04-29 | 1 | -0/+4 |
* | eng: Remove scope from constraints | Sebastian Huber | 2021-04-29 | 1 | -4/+0 |
| | | | | | | Use links instead of this special purpose attributes. Update #3715. | ||||
* | eng: Add unit test link role | Sebastian Huber | 2021-04-29 | 1 | -2/+23 |
* | eng: Remove embedded constraints | Sebastian Huber | 2021-04-29 | 1 | -44/+1 |
* | c-user: Generate region manager documentation | Sebastian Huber | 2021-04-28 | 2 | -470/+859 |
| | | | | | | | | | The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | ||||
* | c-user: Generate task manager documentation | Sebastian Huber | 2021-04-28 | 3 | -1187/+1761 |
* | c-user: Fix typo "cod" -> "code" | Sebastian Huber | 2021-04-28 | 1 | -6/+7 |
* | c-user: Clarify constraints | Sebastian Huber | 2021-04-28 | 6 | -13/+22 |
* | c-user: Generate scheduling concepts documentation | Sebastian Huber | 2021-04-28 | 2 | -325/+646 |
